ZJ: 98 Grand Cherokee, trans shift problem. (Video included) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2013, 08:40 PM   #1
Badmunky
Badmunky's Avatar
Question 98 Grand Cherokee, trans shift problem. (Video included)
I have a problem with our 98 GC.
The trans is not shifting right when you drive it normally. But shifts fine when you hammer on it or drive it like grandma.
Here is a link to a video of the problem.
There is some more info in the video as well.
So what do you guys think the problem is?
Badmunky is offline   Reply With Quote
Old October 29th, 2013, 03:29 AM   #2
big86inthestixx
big86inthestixx's Avatar
Seems like a governor pressure solenoid to me. What trans, 42re, 45rfe?
Does it act up more as the trans gets up to temp? Seems fine when cold?
sended frum dis stoopid fone
Old October 29th, 2013, 06:13 AM   #3
tj84
tj84's Avatar
check the TPS it can have that same effect on it.
tj84 is offline   Reply With Quote
Old October 29th, 2013, 06:43 AM   #4
revdog
I'd adjust tv cable and make sure the lever on the trans moves freely. Also have you checked for codes?
Sent from my DROID RAZR using Tapatalk 2
revdog is offline   Reply With Quote
Old November 2nd, 2013, 08:24 PM   #5
Badmunky
Badmunky's Avatar
TV cable adjustment done. No change.
No codes.
42RE
Seams to do this more when its up to temp. But will do it at times when cold.
I had the trans serviced and there seamed to be no change.
Old November 2nd, 2013, 08:33 PM   #6
big86inthestixx
No codes.
42RE
Id bet pretty good, that its the gov. Pressure solenoid.
This won't throw a code all of the time.
Last few ive gotten were bout 60 bux plus fluids...I adjusted the bands when I was in doing that as well.
Old November 3rd, 2013, 10:33 AM   #7
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
I'd try the tps as well.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old November 8th, 2013, 05:52 PM   #8
Badmunky
Badmunky's Avatar
How do you adjust the bands?
Page generated in 0.27056 seconds with 48 queries
