JK Sport (2-door) suspension question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 28th, 2013, 08:26 PM   #1
jeeping33
jeeping33's Avatar
Default JK Sport (2-door) suspension question
I have a 2011 JK Sport and am looking to get a slight lift by installing the tera-flex leveling kit and stiffer Rubicon coil springs. My stock spring set up is 5212 front and 6800 back.
Any suggestions or recommendations of what coil springs I should be looking for?
Anybody have the same set up that can give me some feedback?
thank you
jeeping33 is offline   Reply With Quote
Old October 28th, 2013, 11:01 PM   #2
oz97tj
Wasn't this attached?
oz97tj's Avatar
Why not just skip the hassle and get some spacers and be done with it? It'll be simpler in the end and you'll end up with more than a half inch of lift.
********GLFWDA.org********
Old October 29th, 2013, 07:33 AM   #3
Paul04TJ
Small, but talented
Paul04TJ's Avatar
I think I read somewhere its about a 1/4" lift per part number.
Paul04TJ is offline   Reply With Quote
Old October 29th, 2013, 08:34 AM   #4
oz97tj
oz97tj's Avatar
On a good day assuming maximum difference youll see an inch max. Likely less. JKs arent like the old TJs where the Rubi was actually a lift. JKs only accouny for the weights of the vehicle.
Considering the low cost, just buy the spacers and get the desired lift height instead of messing around with springs that wont give you any real lift.
Old October 29th, 2013, 01:44 PM   #5
addsmack
2009 JKU
addsmack's Avatar
Send a message via AIM to addsmack
I have some JKU springs if you are interested. Should give you about 1/4 to 1 inch difference due to spring rate.
Just pick up a RC 2.5" spacer lift - http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Under $200 - clears 35's.
-Adam
addsmack is offline   Reply With Quote
Old October 29th, 2013, 09:17 PM   #6
jeeping33
jeeping33's Avatar
So the stiffer springs will not give me any lift?
Sent from my GT-N5110 using Tapatalk
Old October 29th, 2013, 09:19 PM   #7
jeeping33
jeeping33's Avatar
-Adam
What number are you Rubicon Springs? How old are they?
Old October 30th, 2013, 03:57 AM   #8
oz97tj
oz97tj's Avatar
Yes and no. Stiffer doesnt mean taller. It only means they will sag less under a given weight.
Taller springs, or spacers, will give height though
Old October 30th, 2013, 04:44 PM   #9
addsmack
2009 JKU
addsmack's Avatar
I'll check the numbers when I get home - they are in the back of my garage.
Old November 10th, 2013, 06:55 PM   #10
jeeping33
jeeping33's Avatar
addsmask, did you ever get a chance to look at those Springs?
Old December 31st, 2013, 07:01 AM   #11
2trackin
Jeepster
Did you ever figure out your spring issue? I have the complete suspension from my 2014 Rubicon Sitting in my garage. Doubt you'd see much of a lift. They only have about 500 miles on them.
2trackin is offline   Reply With Quote
Old December 31st, 2013, 03:39 PM   #12
jeeping33
jeeping33's Avatar
I think I have it worked out. I still may be interested in your suspension. Whar number are your Springs?
Page generated in 0.21020 seconds with 59 queries
