4.2l i6... carb swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 27th, 2013, 09:34 PM   #1
nextcoatings
NextCoatings
nextcoatings's Avatar
Default 4.2l i6... carb swap
I am about to swap my original carb on my 258 but I dont know which one is best or why. Any thoughts on a good replacement that will keep me from stalling or sputtering?
nextcoatings is offline   Reply With Quote
Old October 29th, 2013, 04:27 AM   #2
Logdog
I did the MC2100 swap thats well documented around the interwebs. Im pretty happy with it overall. No sputtering or stalling. On road or off. I did the swap the same time as an HEI distributor so it's hard to say which had the bigger positive impact on how it runs
Logdog is offline   Reply With Quote
Old October 29th, 2013, 04:46 AM   #3
mexdsk
goofy
mexdsk's Avatar
I went all the way and did a howel FI conversion. Obviously more expensive, but mine has never run better.
mexdsk is offline   Reply With Quote
Old October 29th, 2013, 06:40 AM   #4
0llllll0
JeepJohnson
0llllll0's Avatar
I also did the 2100 swap and have been very happy with it once I got it set up correctly. At first I bought a used 1.08 venturi Motorcraft 2100 that included a mr gasket adapter (junk) and size 50 jets, which were to big for my set up. I got a new adapter from GRONK which was a perfect fit, rejeted it with #47 jets (from Allstate carb http://www.allcarbs.com ) and added the electric choke. It runs excellent now and I was able to modify my stock air cleaner for a clean look.
Also, if you haven't done the nutter bypass and the HEI or Juice Box Ignition upgrades, they are also highly recomended...
Here are a few pic's that show my set up and show all the wires and computer you can remove by doing the nutter...
Good luck with your project.
Jeepjohnson
"Black Foot" my CJ-7 build
Do you have a YJ ? Is the rear Frame rusted ? Check this out YJ Rear Frame Reinforcement Plates
0llllll0 is offline   Reply With Quote
Page generated in 0.17780 seconds with 35 queries
