XJ: 97 XJ, weak heat - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 27th, 2013, 03:30 PM   #1
skife
skife's Avatar
Default 97 XJ, weak heat
heater on my G/Fs XJ blows luke warm... moving the blend door it will get cold and then back to luke warm, I flushed the heatercore with water until it was pouring out clear, and it seemed to help slightly.
G/f isn't happy she is cold, help please.
Old October 27th, 2013, 03:32 PM   #2
Mudking
Mudking's Avatar
Mine is that way to. On high heat its hardly warm. On low its warmer
Sent from my DROID RAZR HD using Tapatalk 2
Mudking is offline   Reply With Quote
Old October 27th, 2013, 03:48 PM   #3
firehawk
Live Action!
firehawk's Avatar
Either clogged heater core or bad thermostat.
Old October 27th, 2013, 04:28 PM   #4
WACKO1
2000 xj
WACKO1's Avatar
Plugged heater core
WACKO1 is offline   Reply With Quote
Old October 27th, 2013, 07:01 PM   #5
skife
skife's Avatar
going to flush it with acid tomorrow
Old October 27th, 2013, 08:07 PM   #6
t_ank
t_ank's Avatar
Flush it both ways. I hooked hoses end to my lines n threaded the house on so it got max pressure
t_ank is offline   Reply With Quote
Old October 27th, 2013, 08:38 PM   #7
Flexin' XJ
Flexin' XJ's Avatar
Don't leave the acid in too long. I flushed one at the dealer once and left it in a tad too long and it ate through the core. And if anybody knows how hard it is to replace a core on an S series Blazer, it wasn't worth it.
Flexin' XJ is offline   Reply With Quote
Old October 27th, 2013, 10:16 PM   #8
montecarlo33
The Violator
montecarlo33's Avatar
Where do you get the acid? Battery acid?
Old October 27th, 2013, 10:20 PM   #9
Flexin' XJ
Flexin' XJ's Avatar
Carquest sells a radiator flush which I think is hydrochloric acid. Or something similar.
I would use a long transmission funnel which fits well into the hose end. But the acid will soften the plastic.
Old October 28th, 2013, 03:41 PM   #10
mudviper
getting dirty
mudviper's Avatar
Send a message via Yahoo to mudviper
Try burping the system. I did all the stuff you did and still only put out luke warm air. After burping the system, getting all the air out, it start to push the heat out.
mudviper is offline   Reply With Quote
Old October 28th, 2013, 05:08 PM   #11
skife
skife's Avatar
trying to flush the core with vinegar right now.
Old October 28th, 2013, 06:51 PM   #12
skife
skife's Avatar
slightly better, going to put a thermostat in it tomorrow.
Old October 28th, 2013, 08:44 PM   #13
Mudking
Mudking's Avatar
Ours (my wife's dd also) runs just under 210 all the time. So didn't imagine a tstat helping. I'm gonna try the same this weekend. Flushing and burbing
Old October 28th, 2013, 09:09 PM   #14
firehawk
Live Action!
firehawk's Avatar
You can check the temps of the hoses to see if the coolant is flowing, check at different spots like at the upper radiator and lower and the heater hoses. An infrared or laser thermometer is easiest but contact thermometers can work too.
This can tell you if the thermostat is not opening or if the heater core is clogged.
Old October 29th, 2013, 06:44 AM   #15
skife
skife's Avatar
Upper rad hose was warm when temp gauge said 205, heater hose that's up there is just warm too.
coolant is brown and nasty. This weekend itll get wheel bearings and a coolant flush
Old November 4th, 2013, 05:31 AM   #16
skife
skife's Avatar
Coolant flush didn't help much.
Old November 4th, 2013, 11:53 AM   #17
95ZJTIM
95ZJTIM's Avatar
time for a heater core. Fun stuff. weekend repair if you DIY
95ZJTIM is offline   Reply With Quote
Old November 4th, 2013, 07:15 PM   #18
firehawk
Live Action!
firehawk's Avatar
Check the diverter valve by the firewall
Page generated in 0.32837 seconds with 77 queries
