93 YJ 2.5L backfire - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 26th, 2013, 08:58 PM   #1
dochereford
Default 93 YJ 2.5L backfire
Okay, so I'm thinking I have a broken valve or something because the timing is steady (with a light). It will run smooth for a spell, then start back firing pretty bad, stalling, then it will smooth out again.
Any heads up suggestions before I tear into it?
dochereford is offline   Reply With Quote
Old October 26th, 2013, 09:49 PM   #2
Torg38
TorgFab
Torg38's Avatar
Vacuum gauge..... If it's steady it's an ignition problem if it's shaking all over the place it's a valve train problem.
Torg38 is offline   Reply With Quote
Old October 26th, 2013, 10:02 PM   #3
dochereford
sprayed ether all over intake . no change in idle. i hook a vac to it and check tho. thx
Old November 7th, 2013, 12:46 AM   #4
dochereford
Wow. Okay. I need some direction from some seasoned troubleshooters.
Vacuum held steady during backfires so I figured I had a ignition issue. Replaced cap, rotor, wires, plugs. Everything except coil. (hmm)
I noticed some water blowing out of tail pipe. Didn't seem like the normal condensation you get. So with that and the backfire, I decided to just pull the head, do a value job and be done with it.
I get it all back together. Runs great in the garage. I let it run for about 30 minutes to check coolant levels and such. Awesome
I take it for a spin and after about 5 miles, it starts doing the same thing again. (Nice going einstein. You did all that for nothing.)
I need a clue. I'll take a couple if you have some.
Old November 7th, 2013, 01:42 AM   #5
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
Distributor shaft loose?
Old November 7th, 2013, 09:50 AM   #6
dochereford
You mean, does it turn? No its tight.
Old November 7th, 2013, 09:54 AM   #7
firehawk
Live Action!
firehawk's Avatar
Coil?
Old November 7th, 2013, 10:21 AM   #8
Toyfish
Toyfish's Avatar
tps
Old November 7th, 2013, 10:34 AM   #9
Wramblerguy
Wramblerguy's Avatar
sounds like it might be getting too much fuel
3rd generation jeeper
Old November 7th, 2013, 11:10 AM   #10
dochereford
Well, I'm done guessing. Too expensive. I need a method to start troubleshooting and frankly, I don't know where to start.
Old November 7th, 2013, 12:02 PM   #11
GNJEEPN
Grumpy Grampa
GNJEEPN's Avatar
Just a thought have you checked that the plug wires are on correct? Proper firing order. I had someone mess with mine once and it acted similar to yours.
GNJEEPN is offline   Reply With Quote
Old November 7th, 2013, 02:41 PM   #12
dochereford
Timing is bouncing a little. When it misses and backfires, timing moves even more.
ONLY HAPPENS when its at temperature. Cold, it runs great.
I'm going to replace the distributor. One at auto zone comes with a new module. I figured it will eliminate two things. Module and cam drive gear.
If that doesn't work, I don't know what to tackle next. (...new engine...jeez)
Old November 7th, 2013, 02:43 PM   #13
Wramblerguy
Maybe a worn timing chain but I wouldn't think so because it stays running
If it comes to it I have motor that just needs an oil pan.....
Old November 7th, 2013, 03:23 PM   #14
wilinsonlevi
Team Thumbs Up
The bushings go bad and cause misfire/ detonation. The shaft will actually be sloppy, pull cap if and see if rotor wiggles if it does replace distributor.
Old November 7th, 2013, 03:34 PM   #15
GREASYHANDS
GREASYHANDS's Avatar
Coolant temp sensor? If it only does it warm and you think its getting to much fuel I would guess ect
Bare Bones Offroad
RIP FS4L
Pavement sucks
Meow
Old November 9th, 2013, 01:14 PM   #16
dochereford
Update Solution:
Bad wire on the Crankcase Position Sensor. It was cutting in and out.
Tags
2.5l, backfire
Page generated in 0.24327 seconds with 71 queries
