Tons of Jeep and Misc parts (Kiel, WI) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 24th, 2013, 07:35 AM   #1
jeepthing360
Default Tons of Jeep and Misc parts (Kiel, WI)
Hello. Here is a list of a ton of different parts I’m selling. I’m cleaning house of everything that I have. I do have pictures of most of the parts if you would like them. I will do package deals on whatever you would like. I will ship any part on buyers dime. As stuff sells I will update the list with SOLD next to the part. I’m pretty sure I have listed everything, but if I do find more I will list it at the bottom with a *** next to the part. If you have any questions feel free to post or PM me. Thanks for looking
ZJ (Most parts off a 94 ZJ)
Front and Rear Leather Seats (Tan) $50
2 Sets of Front Cloth Seats (Grey) $25 1 SET SOLD, 1 SET LEFT
1 Passenger Tail Light $5
Power Steering Box $25
Passenger Front Door (Silver) $25
Set of Rear Doors (Silver) $40
Front Driver Air Bag (Black) $20
B053V8 K&N Air Filter $10
Ford Taurus Electric Fan $40
Transmission Cooler $5
46RH Transmission with Torque Converter $150 Sale pending
CJ (Most parts off late 70’s early 80’s)
CJ-7 Black hardtop complete $300 SOLD
Renegade Hood and front fenders (Good shape) $350 SOLD
Front Turn Signals $5
Rear Side Signal Markers $5
Heater Dash Lights $5
13x3 K&N Air Filter $10
55 Amp Alternator $20
63 Amp Alternator $20
Headlight with Bucket $5 (SOLD)
Used Polyurethane V8 Engine Mounts $15 SOLD
Window Cranks $5
Spring Perches (New) $5
Shackle Hangers (New) $5
XNSM Inspection Cover $5
Shifter Boot $5
Steering Box Brace $5 SOLD
Universal Shifter Boot $5
Transfer Case Shifter Boot $5
New Polyurethane V8 Motor Mounts $25 SOLD
029156 AMC 5461585 York Air Pump $20 SOLD
Front Rear Spring Plates $5
Front Spring Plate with Sway Bar Mount $5
Front Turn Signal Housing $5
Rust Free Striker Plates $10 SOLD
CJ 7 Dash Lights $5
CJ7 Dash $40
Grill $30
Passenger Wiper Arm $5
CJ7 Hard Top Side Glass $15
Black Mirrors $25 SOLD
Bell Housing and Shift Fork $10
A/C Pump $20 SOLD
3 Belt Crank Pulley $5 SOLD
2 Dust Shields $5
Heater Duct $5
Steering Wheel Wire Cover $5
Center Console $20
Chrome Glove Box Cover $10
1 Inch Fan Spacer $5
Tail Light Side Markers $10
Auxiliary Rear Heater with Fan $25 SOLD
Chrome Steering Wheel Cover $10
15x7 Inch Rim 15 on 5.5 $15
15x8 Inch Rim 15 on 5.5 $15
Black Steering Wheel Cover $5
CJ Power Steering Box $50
CJ5 Rear Drive Shaft 16 x 19 2 Inch $20
CJ Front Drive Shaft 21 x 23 1 Inch $20
CJ Front CV Shaft 26 Stuck 1 Inch $20
CJ Rear Shaft 18x21 2 Inch $20
TJ
Passenger Rear Warn Pocket Flare $5
Driver Front Warn Pocket Flare $5
TJ Spare Tire Spacer $10
FSJ (Most parts off 87 J-10)
Rhino Grill with Emblem and Pie Pans $350
Front Dana 44 (New Front Brakes, with ton calipers and pads and New Front U Joints, Warn Quarter Turn Hubs 3.31 gears) $400
Rear Dana 44 (Disc Brake Brackets not installed, comes complete with factory brakes also, 3.31 Gears $200 or $500 for the set
Wood Grain Glove Box Door $10
1 set Doors off 87 J-10 (rough shape but complete) $50
1 Set Doors off 74 J-10 (mismatched color but complete) $50
Rear Sliding Window $75 SOLD
Power Steering Box $30
27 inch Front Drive Shaft $20
Fuel Filler Assembly $5 SOLD
4 Inch Lift Kit (Shocks,springs, new U-bolts, new brake lines) $450 SOLD
3.4 Ton Tow Rings $5 SOLD
16 Inch Trico Winter Wiper Blades New $10 SOLD
Rebuilt 727 Transmission/NP208 Transfer Case with B&M Transmission Temp Gauge $250 Sale pending
87 Black Dash Insert $20 SOLD
Cargo Lamp Switch $5
Battery Tray $5 SOLD
Manual Choke Cable $5
Stainless Steel Braided Throttle Cable $20 SOLD
V8 Engine Mounts $10 SOLD
727 Transmission Filter WIX Part Number 58707 $10 SOLD
Tan Front Bench Seat $40 SOLD
Heater Control $10
67 Rear View Mirror $5
Fuel Filler Hoses New $10 SOLD
Passenger Tail Light $10 SOLD
Heater Core and Box $25
Headliner Trim $5 SOLD
Transmission Tunnel Cover $5
Square Front Headlights with Buckets $10
Amber Front Turn Signal Covers $5 (1 set SOLD, 1 set left)
Black Exterior Mirrors $10
Front and Rear Aftermarket Bumpers $150 each Rear SOLD
Headliner $10
Cowl Cover $10
Chrome Windshield Trim $10 SOLD
Power Brake Booster and Reservoir $30 SOLD
New Disc to Disc Brake Proportioning Valve $60
Tan Armrest $5 SOLD
Rear Drive Shaft 4”x64” $20
Rectangle Headlights and Buckets $10
Vacuum Canister $5 SOLD
2 Inch Dual Exhaust $20 SOLD
Tilt Steering Column $25 SOLD
2 Steering Shafts $5 1 SOLD 1 LEFT
Door Seal Trim $5 SOLD
Windshield Wiper Motor $10 Sale pending
Windshield Washer Reservoir with Pump $5
Instrument Cluster 127,000 $10
Blower Motor $10 Sale pending
Front Door Seals $5 SOLD
Sun Visors $5
Metal Tailgate Straps $5
Axles
Ford 10 with Rear Disc Brake Brackets 3.55 Gears $200
1999 Ford Dana 60 3.73 Gears minus brakes, hubs, and driver side axle shaft $150
Misc
12x10 8 Tube Transmission Cooler $10
8x8 4 Tube Transmission Cooler $10
CA-4001 120 Inch Speedometer Cable Repair Kit $5 SOLD
Seat Massager $5
Grey and Black Bench Seat Cover $5
Aftermarket Chevy Steering Shaft $10
Choke Conversion Kit $5
B&M Transmission Shifter $50 SOLD
Fram CA3901 Air Filter $5
Wagner Bright Light H6054BLL Headlights $5
Cam Ball $40 each or $75 for both
220 V Plug 100 amp $25
WJ Right Rear Door Window $25
WJ Liftgate Window $35
WJ Window Motor $20
Truck Side Mirrors $10
Chevy Shaft 26 Stuck 2 Inch $20
Chevy Shaft 34 Slip 2 Inch $20
Chevy Shaft 42 Stuck 2 Inch $20
Chevy Shaft 51 x 54 3 Inch $20
SM 465 2WD 35 spline output (complete) $100 SOLD
Parts added.
*J10 Brake booster and reservoir $40 SOLD
*ZJ Power steering box $40
*CJ headlight guards $5
*Black WJ rear headrest $10
*TJ (4) two tone rims 15*7 5 on 4.5 $100
jeepthing360 is offline   Reply With Quote
Old October 28th, 2013, 06:53 AM   #2
jeepthing360
Monday morning bump
Old October 28th, 2013, 07:36 PM   #3
tom tom
tom tom's Avatar
Can you post pics of the aftermarket bumpers
tom tom is offline   Reply With Quote
Old October 30th, 2013, 06:00 AM   #4
jeepthing360
Here are some pictures of both of them. The front is basic, but is made out of all stainless steel.
[IMG]URL=http://s1139.photobucket.com/user/jeep-thing-360/media/IMAG00162.jpg.html][/URL][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old October 30th, 2013, 07:10 AM   #5
topjimmyk
topjimmyk's Avatar
Can u post some pics of the trans coolers?
topjimmyk is offline   Reply With Quote
Old October 31st, 2013, 07:05 AM   #6
jeepthing360
I will get some pictures of all the coolers I have tonight.
Old October 31st, 2013, 07:27 PM   #7
jeepthing360
Here is a picture of the 3 coolers I have.
Old November 2nd, 2013, 08:26 AM   #8
jeepthing360
Saturday morning bump
Old November 5th, 2013, 06:53 AM   #9
jeepthing360
Parts added.
Old November 5th, 2013, 12:07 PM   #10
AlanKal
How many miles on the zj trans
Sent from my HTC6500LVW using Tapatalk
AlanKal is offline   Reply With Quote
Old November 10th, 2013, 09:33 PM   #11
jeepthing360
I know most of you are from Michigan but, I will be heading down to Austin, TX Wednesday so if anyone wants parts and to save on shipping let me know. I will be going through Des Moines, Kansas City, and Oklamhoma City. If there is anything you want let me know. Shoot me some offers I want all this gone.
Page generated in 0.38138 seconds with 56 queries
