Tire size help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 22nd, 2013, 08:22 AM   #1
loc223
Default Tire size help
I have a 2000 tj. I am installing 2" budget spring spacers and front tube fenders with minimal flare. I plan to run a stock wheel, what is my limit on tire size? Also recommendations on wheel change. Should I go with a 16 for more tire options or something with a different spacing to stay away from tire rub? I would like to run an AT tire.
loc223 is offline   Reply With Quote
Old October 22nd, 2013, 08:27 AM   #2
Lousypirate
Whoop Whoop
Lousypirate's Avatar
31x10.50x15 should fit fine... with swaybars attach iirc.
The Kernel (46 CJ2a)
Wow, i would lick those...
Old October 22nd, 2013, 08:28 AM   #3
Zach4739
2005 Willys
Zach4739's Avatar
i have a 3.5 on my tj with no sway bar. i run 31s and they rub a little in the front at full flex.
id recommend 31s, tjs look foolish with giant tires and no lift
Zach4739 is offline   Reply With Quote
Old October 22nd, 2013, 08:57 AM   #4
RADRICK
RADRICK's Avatar
On my TJ I have a 2" BB, 32/11.5/15 on 8" wheels. I get no rub when turning sharp. I have yet to flex it, but I did extend all 4 bump stops to prevent the tires from chewin on the flares during flex. Most places I have read say a 11.5 or wider tire will rub when turning unless you get a wheel with more offset.
Old October 22nd, 2013, 09:01 AM   #5
loc223
I would like to stay with a narrow tire. 9.5 0r 10.5
Old October 22nd, 2013, 09:02 AM   #6
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
33s easily fit on my tj with a bb and trimmed flares. Aftermarket wheels though.
Old October 22nd, 2013, 01:48 PM   #7
Paul04TJ
Small, but talented
Paul04TJ's Avatar
I had 2" lift with 31x10.5-15, stock Rubi Flares, never Rubbed when disconnected.
With Tube fenders maybe 33's I'm guessing.
Paul04TJ is offline   Reply With Quote
Old October 22nd, 2013, 06:59 PM   #8
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Really?
With the right fenders you don't need much lift to run big tires. My jeep has 4.5" springs which have sagged down to about 2.5" with the sbc. Flat fenders front and rear with 35s. My last tj had 2.5" springs and I added 1.25" coil spacers up front to level it out. No sway bars, 32s and stock fenders rubbed a pinch at times.
The only pic I have on my phone of my old one in 32s
This is the new one on 35s. The front is actually a touch lower than my old jeep. I want to drop the rear down to 2.5" springs so it sits level.
Page generated in 0.23028 seconds with 47 queries
