Shop clean out Jeep parts, cummins parts, superduty parts, drive shafts, springs etc - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 21st, 2013, 12:21 PM   #1
ty_mock
Default Shop clean out Jeep parts, cummins parts, superduty parts, drive shafts, springs etc
I went through and started cleaning shelfs off from my last build of extra or no longer needed parts and some other stuff that is time to get outa my way.
First off I have a set of 6" lift coils for a TJ. They were new last spring and only ran on my toy for about 6 rides. were like 150-160 new off ebay.
$75
Got a set of skyjacker shocks 14" travel also new last year. one is junk from over extending the others are good. were like 130 new.
$50
Have a set of red eibach coil over springs for 2" shocks. 14"x #350
$70 shipped
got a set of propane tank mounting brackets.
$40 shipped
Got a set of 4 used 4" intercooler boots they have like 3 clamps also.
make offer
have an exhaust manifold for a cummins. Divided outlet exit between 4 and 5 with round ports
$75
Have some 94-98.5 12 valve cummins stage 4 ddp injectors fresh $600 shipped.
94-98.5 12 valve cummins comp cut DV's $200 shipped.
Have a used power steering pump. Saginaw P pump was a reman from napa last fall only 1-2 rides on it. comes with pulley, reservoir, pressure line from pump to GM hyroboost and, a small cooler.
$125
Power steering pump and pully from a 2003 ford f250 with 6.0 powerstroke.
$75
Fuel pump/filter assembly from a 2003 f250 6.0 powerstroke
$100
Stainless steel -4 brake lines I have 2 30" long with fitting adapters for ford calipers to -4. both ends off hose are -4 female. think they were russel from summit also new last spring. I have 1 that is 21" long and comes with a 1/8 pipe to -4 and a 3/16 brake line compression to -4 fittings.
$15 shipped each with listed fittings
Coil spacers for a 2005-2007 superduty brand new never used
$75shipped
92 ford f150 In tank rear fuel pump and sending unit from a rear tank. Plug is broke but is still functional worked when truck was took apart.
$50
Ford 205 input gear.
$50
Pioneer DEH-4900ib stereo Good condition comes with box and manual missing harness. Not stolen as I still have the box just lost the harness. I would think you could buy a new one or use an old harness and replace dif unit with this one. I pod capable.
$50
Pioneer DEH-6700mp stereo good condition comes with box and manual. Harness included on this one. Nice good stereo everything worked when removed.
$75
Ballistic fab coil buckets used missing frame mounts obviously.
$25
got a small sunpro black faced 8k rpm tach works
$25
4 Axle shaft seal and retainer for 2.5 ton Rockwell front axle. comes with the seal retainer and new seal. all brand new oem parts.
$60 pair shipped or $35 each
14 bolt 4.10 gears
$50
yokes
2-1310 32 spline 2.125 seal
1-1310 32 spline 1.875 seal
1-1330 32 spline 2.125 seal
1-1330 32 spline 1.875 seal
1-1330 29 spline D60 front
$50ea shipped some may come with straps if I have ones that fit
got 2 Rockwell tie rods not bent tight end also.
$100 ea
d shafts
2-33" compressed 1330 with cv's on one end 2.5 tube 90's f350 front
1-35" 1330 2.75 tube f150 front
1-1330 with 16" of 3" tube cut with a 1330 weld on not attached
1-1350 cv with 17" of 2.75 tube front from a superduty.
all have good joints maybe a little rusty and one is missing a joint cap other than that their good shape for a diy shaft maker.
make offer on what you want.
2 radiators one from 92 f150 single core with trans cooler and one from 97 f350 with 460 2 row. $50 each
stock intercooler from a 2003 f250 6.0 diesel
$150
have a partially complete 6.0 powerstroke engine from a 2003 to part out as well with lots of new parts if anyone need anything
some of these items will also be listed on ebay as well.
Call or text 4194945122 for info everything located near Toledo ohio
ty_mock is offline   Reply With Quote
Old October 24th, 2013, 02:41 AM   #2
ty_mock
Bump
Old October 24th, 2013, 07:01 PM   #3
bpracing
bpracing's Avatar
r the coil springs and lift blocks still available
bpracing is offline   Reply With Quote
Old October 27th, 2013, 11:08 AM   #4
ty_mock
Bump
Old October 28th, 2013, 12:55 PM   #5
farmerjon
farmerjon's Avatar
pm'ed
farmerjon is offline   Reply With Quote
Old November 1st, 2013, 08:45 PM   #6
ty_mock
Bump
Old November 11th, 2013, 07:07 PM   #7
ty_mock
Ttt
Old November 20th, 2013, 09:24 AM   #8
ty_mock
To top
Page generated in 0.24716 seconds with 47 queries
