XJ: Renix 4.0 stumble and back fire at 2200rpm - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 20th, 2013, 05:11 PM   #1
snocross2xtremes
snocross2xtremes's Avatar
Default Renix 4.0 stumble and back fire at 2200rpm
Renix 4.0 stumble and back fires at 2200rpm. Idles good and runs good at higher Rpms.
Old October 20th, 2013, 06:01 PM   #2
WACKO1
2000 xj
WACKO1's Avatar
Timing is off
WACKO1 is offline   Reply With Quote
Old October 20th, 2013, 06:22 PM   #3
itselliott
itselliott's Avatar
whaat kind of dizzy ?
if it still has a vacuum advance.......check the unit to ensure it moves smoothly.
Check the timing chain backlash (crank to dizzy)
You are runnink OK at full advance and may actually be getting it. but the timing is off at lower rpm showing a mechanical lag in timing.
Assumed all vacuum leaks are inspected and fixed if there were any.
Old October 21st, 2013, 09:14 AM   #4
snocross2xtremes
Non vacuum dizzy. Brand new timing chain. As far as I can tell no vacuum leaks. Also no check engine light
Page generated in 0.14056 seconds with 35 queries
