Makin changes to the buggy, MuddyPaws 4.0 - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 5th, 2014, 09:25 PM   #101
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Test fit of the window. Still have to drill for mounts, wiper, do the paint and all that.
Old March 5th, 2014, 10:31 PM   #102
crunchedtj99
is that glass and seal easily available and can u make more???
crunchedtj99 is offline   Reply With Quote
Old March 5th, 2014, 11:18 PM   #103
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I cut the frame out with a plasma and then took it over to Safe-Lite Glass. They made a pattern and cut the glass for me. The seal is available. If I had dimensions on what you wanted, yea, I could make more frames then you just take it to a glass place and have them cut it.
Old May 2nd, 2014, 11:09 AM   #104
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Got the windshield done.
Old May 2nd, 2014, 11:50 AM   #105
Needs moar turbo!
Old May 2nd, 2014, 02:47 PM   #106
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Needs moar turbo!
Needs more something....but it isn't getting it. LOL
Old May 2nd, 2014, 02:48 PM   #107
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Needs more rev limiter!
Old May 2nd, 2014, 02:51 PM   #108
Come awn, ebay turdbo's are cheap. I see old mitisubishi stuff on craigslist for under $100. Give those kids a lesson on atmosphere and A/F ratio's
Old May 2nd, 2014, 11:30 PM   #109
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I keep looking at the supercharger kit but the cost is just short of half of the total I have into the buggy. :P
Old May 3rd, 2014, 05:22 AM   #110
crunchedtj99
ti we can throw a turbo on it much cheaper if you are serous about boosting it. i think i have a turbo laying around that would even be a good size lol
Old May 3rd, 2014, 06:44 AM   #111
Looks good but I think you should have kept the frame lower than the cage at the top. You will likely crack the window if (when) you put it on its lid. Are you doing wipers?
Old May 3rd, 2014, 08:17 AM   #112
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
It's a little deceiving but it is a little lower than the top. Most of the stuff is just flops anyway. I'm not overly worried about it.
Yes, doing wipers at some point this summer.
Old September 22nd, 2014, 11:21 PM   #113
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Ok, next round of upgrades dictated by a Sunday Funday attempt at the Bounty Hill after a run a the club comp.
Broke 4 ARP studs on the steering arm, cracked the knuckle in 2 places, exploded a trunion bearing, broke the center pin on the steering arm, bent leaf spring, broke u-bolt and bent the axle housing so bad it required a slide hammer to get the axle shaft out.
So I am in parts collecting mode....
So picked this up from a guy on here.
Axle tubes are this as shit at 5/16 inch and the center section is 3/8 inch.
Forged, 1035 knuckle balls
Toss in a set of 6 shooter knuckles
And a set of 6 shooter arms and a set of "Super Metal" studs....whatever the hell that is. Sounds cool though.
The knuckles and arms are in the process of being powder coated so that is why they look weird. They are in the middle of outgassing and sand blasting.
Also planning on getting rid of the trunning bearings for the much stronger king pin-ish eliminators.
Then top the whole thing off with a yet to be determined front 3 link with a 7 or 8 inch front stretch, a 3 or 4 inch rear stretch and a 4 inch lowering job.
Old September 23rd, 2014, 10:04 AM   #114
Good Shit Tim!
Old September 23rd, 2014, 10:15 AM   #115
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Buggy TIM!
Old September 23rd, 2014, 10:53 AM   #116
Ready for loonie?
Old September 23rd, 2014, 08:04 PM   #117
1TFROT
1TFROT's Avatar
looks like a nice list of upgrades!
1TFROT is offline   Reply With Quote
Old September 23rd, 2014, 09:21 PM   #118
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Originally Posted by Mr. Beefy View Post
Buggy TIM!
Don't forget the F
Ready for loonie?
It will be ready, just not with this round of upgrades. I'm patching it back together though.
Old October 1st, 2014, 01:26 PM   #119
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Done yet?
Old October 5th, 2014, 08:11 AM   #120
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Well I put one of my spare knuckles on the bent housing and pounded the axle shaft back in for one more run. Survived Loonie with only a minor mishap. Coming down out of OutBack I picked up a log that was about 7 feet long that went up through the tube work in the rear and hit my fuel pump. Almost tore the pump off the frame, kinked the line and ripped off the ground wire for the pump so it quit going down hill right in the middle of the trail. It also came out the side of the rig and blew one of the aluminum side panels off.
Had to saw the log out and then trail fix the wires to get back. Adding some protection to the fuel pump for this winter's mods.
Gonna start mods this week. I think Loonie is the last run for this season.
Page generated in 0.47782 seconds with 83 queries
