Makin changes to the buggy, MuddyPaws 4.0 - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 22nd, 2014, 06:26 PM   #81
If only there was a way to make bolts shorter........
Old February 22nd, 2014, 06:50 PM   #82
BigBird
Duck Shootin' Wheelerer!!
BigBird's Avatar
and still keep his fingers?!?!
Cheap Thrills Off Road
Old February 23rd, 2014, 08:08 AM   #83
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Originally Posted by bluminade View Post
looks good, i had mine like that and after it got wormed up it started steering hard and it turned out the center clamp was pinching the cylinder and not letting the rod move freely. just an fyi if you have any problems.
I'll remember that. Thanks.
Old February 26th, 2014, 06:51 PM   #84
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Got kicking with the plasma this evening and made a windshield frame.
Old February 26th, 2014, 07:53 PM   #85
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Looks nice
Old February 26th, 2014, 08:24 PM   #86
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Gotta figure out how to mount it and make it removable too. Shouldn't be too hard. Putting regular safety glass in it. Add a wiper and i'm all set.
Old February 26th, 2014, 08:40 PM   #87
Tab
Tab's Avatar
Why real glass? I'm assuming you're going to take it off every time you wheel right? If not it would get expensive replacing glass every time the frame flexes and it cracks or if you hit something.
Old February 26th, 2014, 09:26 PM   #88
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I didn't bust the front window every time I took a Jeep out in the past 2 decades. That window frame isn't going to flex all that much...and even if it did, the window is mounted in rubber.
Real glass because I can then have a wiper and clean the mud off the front window without it being all scratched to hell like lexan does.
Old February 26th, 2014, 10:38 PM   #89
Tab
Tab's Avatar
I figured you'd wheel the buggy a little differently than an xj, maybe not. I wouldn't use lexan either, too much like plexi glass.
Old February 26th, 2014, 11:22 PM   #90
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I busted lots of side windows....just not many fronts. Even if I roll it I don't think it would break.
But the front window is only 50 bucks.
I used a couple different front "plastic" type windows and unless they are glass, they scratch and then suck and then I would have to replace them after every couple runs anyway.
Old February 27th, 2014, 03:56 AM   #91
I like glass.
Old February 27th, 2014, 06:59 AM   #92
If you wanted a windshield, doors, and heat you should have found another YJ instead
Old February 27th, 2014, 10:54 AM   #93
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I just want a windshield. Driving with my eyes watering all the time sucks.
Old February 27th, 2014, 10:59 AM   #94
Monster stickered MX goggles brah
Old February 27th, 2014, 12:19 PM   #95
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
ahahha I know it. Did that once. Wife will not do it....no matter what. She'll just bitch all day her eyes are watering.
I took that damn thing for a ride the other night with no window and thought I was going to die it was so cold. I'm a wimp. There is a reason that most guys with with back halfed, buggyized rigs still keep their windshield.
Old February 27th, 2014, 01:19 PM   #96
Gunsworth
Gunsworth's Avatar
Im still rocking the tube fenders from that first build. Theyve survived many trees and a ford escape. However, I found out what hapens when the fenders are no longer the weak point....
Old February 27th, 2014, 01:22 PM   #97
Mr. Beefy
BFT!
Mr. Beefy's Avatar
So my welds are still holding then?
Old February 27th, 2014, 01:27 PM   #98
Gunsworth
Gunsworth's Avatar
Fo sho, jeep hasnt moved under its own power in 2 years though. But the years of wheeling I did with them, I definitely put em to use, and my cowl shows it. Are you also responsible for drilling the mounting holes? I wouldnt brag about those lmao
Old February 27th, 2014, 01:39 PM   #99
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Nope I just welded
Old February 27th, 2014, 08:16 PM   #100
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
hahahahahaha
Page generated in 0.37464 seconds with 83 queries
