Makin changes to the buggy, MuddyPaws 4.0 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 30th, 2013, 07:05 AM   #21
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
It had 4.10's.
I had a set of 5.29's for my other project that I put in right before the Loonie Run but during the Loonie I found out I really needed the HP front so I sold off the front LP with 5.29's and a locker.
Old October 30th, 2013, 07:29 AM   #22
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Buggy Tim
Old October 30th, 2013, 07:33 AM   #23
crunchedtj99
dang then double low 1rst must now not go anywhere lol. unstoppable slow crawl
crunchedtj99 is offline   Reply With Quote
Old October 30th, 2013, 11:01 AM   #24
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
It got stuck in single low 5:1 in the one tcase in Canada because the shifter fell out. In 5th gear I was wound out at earth scorching 15 mph.
Old October 30th, 2013, 11:15 AM   #25
crunchedtj99
you got to be careful the mounties don't take well to those kind of shenanigans
Old October 30th, 2013, 11:23 AM   #26
It sounded cool though...........
Old October 30th, 2013, 12:09 PM   #27
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I wish someone got video of that last climb before we packed up.
Didn't help that I was stuck in super double low.
5th gear, 4000 rpm, 15 mph.
https://www.youtube.com/watch?v=OSSn...e_gdata_player
Old October 30th, 2013, 12:10 PM   #28
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I didn't get the water fall, but you got into in the video too.
Old October 30th, 2013, 05:03 PM   #29
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
God that things sounds funny.
Old October 31st, 2013, 06:48 AM   #30
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
That's all i have is 4.7:1....wheeled it like that with 5.29's and 38.5's and now with 5.38's and 40's.....once on the trail i really see no need for another range....the only time i miss standard low is running around on smooth connecting trails. Here in MI its not a issue as i just pop it in high range but down south in the mountains high is a no go lol.
Old October 31st, 2013, 09:19 PM   #31
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Yea, I end up switching in and out a lot. One case is 5:1 and the other is the 2.28. 5:1 is where I am in the rocks but sometimes like the lower double. Then like you say, gotta get higher to go from thing to thing on the trails.
I haven't had it out too many times yet so I am still getting used to it and figuring out what gear works for what.
Old November 3rd, 2013, 08:41 AM   #32
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
So putting a V6 high pinion center in a 4 cylinder low pinion housing presents some challenges.
First the bearing adjusters are way bigger and different. Not the rounded stamped steel like the 4 cyl has. They do not fit.
And the ring gear is noticeably thicker. Thicker is better right? Either way, it don't fit.
So clearancing is required.
Ok, so that's done, then more problems. Pulled all the studs and replaced them with bolts. Toy people know, but others may not know that the studs can pull out. So I replaced them all and put loc tight on them to keep them there.
The problem comes when I put the diff in. The mounting face on the 6 cylinder is far thicker than the 4 cylinder diff I pulled out of there. I didn't catch that before putting it together. So a lock washer won't fit and not enough threads are available for me to feel comfortable with just running a nut with loc tight. So the diff has to come back out, get cleaned back up and all new bolts put in.
I said screw it for now and went on with setting the perches. Got the perches set and burned in. Set caster to about 9 degrees positive. Perches have 3 holes but I decided to use the center and not do the one inch stretch. The 1 inch stretch equated to just about a 2 inch difference in how the driveshaft splines engage at full droop.
Old November 3rd, 2013, 08:55 AM   #33
crunchedtj99
nice work.
Old November 3rd, 2013, 08:56 AM   #34
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Good stuff
Old November 3rd, 2013, 09:10 AM   #35
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Gotta have it all back together and running in less than 2 weeks for a Canada trip. Gonna be tight. I don't have a whole lot of time to work on it between work, professional development stuff, grading for the end of the marking period, parent teacher conferences, and finishing my last work for my Ph.D.
Old November 3rd, 2013, 09:55 AM   #36
crunchedtj99
just have parents do conferences with you hile you wrench :) they can hand you tools
Old November 3rd, 2013, 10:00 AM   #37
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
hahahahaha that would be awesome but i'm doing a bunch of the work here at the house. Since I moved, it's a longer drive to work. Can't just run over in 5 minutes.
Old November 3rd, 2013, 10:44 AM   #38
You gonna be a doctor? I've been meaning to talk to someone about this itch I have..............
Nice work on the dif. It looks good.
Old November 3rd, 2013, 03:33 PM   #39
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I am gonna be a doctor. But not the kind of doctor that makes you call him Dr. But I won't deal with itches. I would have thought that with as long as you have been married, you would have gotten past the itch by now.
Old November 3rd, 2013, 03:36 PM   #40
Wrong itch. Don't have that one.
What will your doctorate be in?
Page generated in 0.33522 seconds with 83 queries
