Makin changes to the buggy, MuddyPaws 4.0 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 19th, 2013, 01:13 AM   #1
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Default Makin changes to the buggy, MuddyPaws 4.0
Under the knife again.
Ok, current plans:
High pinion front, 5.29's, Grizzly Locker
Remove ghetto fab front spring perches and replace with better, low profile, anti-wrap perches
Soften up front and rear springs
Raise driver's seat one inch and move it back as far as it will go
Groove tires
Add wheel spacers to rear
Softening up the springs and putting new perches on should lower the rig about 1.5 to 2 inches, which is good.
Ghetto fab perches
One down, one to go
Pulled a leaf out of the back. Rear pack was pretty stiff and didn't flex too much.
Old October 19th, 2013, 01:14 AM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Every time I look at this thing when it was parked, it would look like one rear tire was toed in. Then park it again and the other tire would be toed in. And the resting shackle angle kept changing. I knew something was wonky in the rear. Found out what it is. Easy fix though.
1/2 inch bolt in a 5/8 or bigger hole.
Between the play in the hole and in the bushing, there can be about a 1/2 inch difference from side to side on the front hanger which translates into over a inch at the wheels.
Old October 19th, 2013, 05:28 AM   #3
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Nice
Old October 19th, 2013, 07:23 AM   #4
choppergar
choppergar's Avatar
choppergar is offline   Reply With Quote
Old October 19th, 2013, 02:11 PM   #5
Mr.Green
I can levitate!
Mr.Green's Avatar
That thing deserves to be 4 linked.
Old October 19th, 2013, 02:21 PM   #6
Tacker
Tacker's Avatar
X2 on the 4 link, along with some air shocks or coilovers .
Old October 19th, 2013, 03:42 PM   #7
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I vote 4 link also, if we are voting.
Old October 19th, 2013, 04:07 PM   #8
big86inthestixx
big86inthestixx's Avatar
X4 on the 4 link.
sended frum dis stoopid fone
Old October 19th, 2013, 04:51 PM   #9
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
hahaha
Can't afford the 4 link yet. Maybe next winter. Maybe not. Nothing wrong with leafs.
Old October 19th, 2013, 07:31 PM   #10
crunchedtj99
can i vote for slider boxes? i tend to like leaf springs i know im weird... lol glad to see progress tim :D
crunchedtj99 is offline   Reply With Quote
Old October 19th, 2013, 08:16 PM   #11
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Been looking at the Liquid Iron Industries boxes for both the front and the rear. It might be hard to get the level between the front and back the same though.
Old October 21st, 2013, 06:54 AM   #12
crunchedtj99
i really want to try that setup. the guy's i have seen with them (only 1 in person) they work really well and have way more travel than a standard shackle. but yeah if you can get them on a level flat surface can be difficullt...
Old October 21st, 2013, 07:18 AM   #13
Mr.Green
I can levitate!
Mr.Green's Avatar
Originally Posted by Buggy_Tim View Post
hahaha
It can be done for pretty cheap. You don't have to start with coil overs, but you can also find good deals on them too.
Old October 21st, 2013, 07:29 AM   #14
I think you need to move the driver's seat further forward. You seemed to struggle reaching the pedals.
Old October 21st, 2013, 08:01 AM   #15
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
3/4 bolt. Much moreer betterer.
Old October 21st, 2013, 08:03 AM   #16
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
I wish someone got video of that last climb before we packed up.
Didn't help that I was stuck in super double low.
5th gear, 4000 rpm, 15 mph.
Old October 29th, 2013, 11:13 PM   #17
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Ok, finally got ahead of things at work and ticked a couple things off the honey do list at home so I had a chance to get a little more done tonight.
Got the new perches.
Machined to fit around the short side of the axle and lower how it mounts to the axle about 3/8 or 1/2 inch. With the other mods to the springs, and getting rid of the funky welded on plates and welded on metal for the home made shims, it should lower the front just about 2.5 inches. I might add some boomerang shackles to allow a more droop with only adding 1/5 inch of lift. So net 2 inches lower and more droop.
Also working on some brackets to get the seat moved up one inch and back. Not done yet. Plans were to run it back 3 or 4 inches, but looks like i'll only get about 2.5 inches back. But that's better than nothing. I'm not chopping up the cage to move the seat back any more. Maybe at a later date i'll swap seats to get it moved back more.
Then got a new shineeey part. High pinion front, Yukon 5.29's and a Detroit. WOOT
Old October 29th, 2013, 11:13 PM   #18
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Then had to deal with this. We know these things get banged up pretty bad. Mine won't come out. In Canada a couple weeks ago a guy ripped his out even though he had the fancy low profile one and he didn't have a spare.
So cut it out, and plate it in.
Grind smooth in prep for some bottom plating.
Made up a 1/4 inch plate to go over the bottom of the diff.
Done
Old October 29th, 2013, 11:34 PM   #19
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Nice
H.o.r.e
Old October 30th, 2013, 06:05 AM   #20
crunchedtj99
what gears did it have in it before?
Page generated in 0.31866 seconds with 83 queries
