Help how to remove d30 carrier - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 18th, 2013, 06:07 PM   #1
99tj4banger
99tj4banger's Avatar
Default Help how to remove d30 carrier
I'm currently trying to instal a spartan in my tj front d30. I've used a pry bar while tapping on the carrier and it isn't budging. Any suggestions?
99tj4banger is offline   Reply With Quote
Old October 18th, 2013, 06:17 PM   #2
Wramblerguy
Wramblerguy's Avatar
If you can't pry it out
I would think a case spreader would be the next option
3rd generation jeeper
Old October 18th, 2013, 06:20 PM   #3
bigbchevy
missmrgreenagain
bigbchevy's Avatar
You have the shafts and everything out of it right?
What I do most the time is take a three foot pry bar And a block of wood and pry on a ring bolt so your pry bar is parallel to the axle tube
H.o.r.e
Old October 18th, 2013, 06:42 PM   #4
Andy456123
Guest
^^^this
and if its still not budging, have a buddy hit the carrier and ring gear area with a dead blow hammer (while still applying pressure with the bar). Hit it from different angles until you find the sweet spot, and the carrier will pop out
And/or get a housing spreader like mentioned above.
Andy456123 is offline   Reply With Quote
Old October 18th, 2013, 07:17 PM   #5
99tj4banger
Did a quick search on the googles and seen a rag trick. You shove the rag between the ring and pinion so it sucks up the rag. That along with a pry bar did the trick.
Page generated in 0.19257 seconds with 38 queries
