Needs thoughts on noise - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 17th, 2013, 07:29 PM   #1
wilinsonlevi
Team Thumbs Up
wilinsonlevi's Avatar
Default Needs thoughts on noise
79 hp kp 60 in 93 yj.
I had a loud popping noise when I I'm in 4x4 coming from passenger side. I thought it was u joint. Took shaft out and u joint is fine, lockout looks fine and I don't see anything in differential. It has a spartan locker with stick ford 30 spline lockouts.
The noise started after I had the tire stuffed really hard and kept trying to go till I bent a leaf spring. I'm wondering if locker is slipping or maybe housing tweaked?
Old October 17th, 2013, 09:10 PM   #2
wilinsonlevi
Team Thumbs Up
The inner shaft splines look a little thin at the top. Doesn't look like they have slipped. Tomorrow night I will pull locker out and see how those splines look.
Old October 17th, 2013, 10:15 PM   #3
Toyfish
Toyfish's Avatar
I would suspect the locker
Sent from my DROID X2 using Tapatalk 2
Old October 17th, 2013, 10:32 PM   #4
jaysusr
jaysusr's Avatar
Break a leaf?
Old October 17th, 2013, 10:53 PM   #5
wilinsonlevi
Team Thumbs Up
I'm gonna pull it tomorrow.
Anyone have issues with a spartan slipping?
Old October 17th, 2013, 10:56 PM   #6
wilinsonlevi
Team Thumbs Up
Originally Posted by jaysusr View Post
Break a leaf?
Didn't break it but bent the main.
Old October 17th, 2013, 11:15 PM   #7
Toyfish
Toyfish's Avatar
I think kylem had some issues with his over the summer
Old October 17th, 2013, 11:21 PM   #8
1 ton tj on 40's
1 ton tj on 40's's Avatar
the shaft looks good. I would think the locker is staring to let go.
Old October 18th, 2013, 06:19 AM   #9
Kyle bent the housing causing the shaft to locker to be slightly out of alignment and forcing the side gear to ride funny in the locker making it slip. The locker wore do to that. Not a typical locker failure.
I wore out the forward edge of the teeth in my lock right and it would slip making a horrible popping noise under load.
If you pull the locker pay close attention to the teeth of the gears for any sign of the edges being worn. If you don't see anything and reinstall it, flip it around so what was the passenger side is now the drivers. If it does happen to be that, atleast then the worn edge of the teeth will be on the reverse side and forward should still hold and not slip.
I replaces my lock right with a spartan. But recently replaced the spartan with a Yukon grizzly. I didn't have any issues with the spartan and sold it somebody who reinstalled it in his axle and hasn't had any issues.
Old October 18th, 2013, 04:01 PM   #10
wilinsonlevi
Team Thumbs Up
Cheapthrills, you were behind me in the woods that first left hander when my right tire was wedged and I kept trying I think is where I bent my spring. You think that could have tweaked axle? Or maybe when I was winching out of mud hole? Axle doesn't appear to be bent just by looking at it but with a good way to measure I'm not saying it isn't. That locker in there had zero issues to the mullet run, not sure what happened. I'm headed out to shed to pull it out now.
Old October 18th, 2013, 04:08 PM   #11
liv2mx
i like jungle gym's.
liv2mx's Avatar
Shaft is fine..locker is fubared...lol
Old October 18th, 2013, 05:12 PM   #12
wilinsonlevi
Team Thumbs Up
Locker is slipping. Any warranty on the spartan locker?
Old October 18th, 2013, 05:31 PM   #13
Wehan
Wehan's Avatar
If your the original purchaser it has a 1 year warranty but it may be void, the Spartan for a Dana 30 has a 32" tire size limit and I think a horsepower limit, not sure if this is true for your axle. That's why I went with an Aussie instead.
Wehan is offline   Reply With Quote
Old October 18th, 2013, 07:58 PM   #14
If you know somebody capable. Have them cut some new edges on the teeth. I did this with my lock right and got almost another year of use.
Old October 18th, 2013, 08:02 PM   #15
wilinsonlevi
Team Thumbs Up
I thought of that, I could have taken it work and got in done in machine shop. I just flipped gears side for side and will hope it holds for awhile. If it doesn't as least I know what the problem is and I will still have limited slip. Lol
Old November 15th, 2013, 07:22 PM   #16
2000ZR2
2000ZR2's Avatar
Taken it to work and got it done in the machine shop. Maybe you should learn to wright a sentance!
2000ZR2 is offline   Reply With Quote
Old November 15th, 2013, 07:25 PM   #17
wilinsonlevi
Team Thumbs Up
Write
Sentence
Old November 15th, 2013, 07:30 PM   #18
Write
Sentence
Win.
Old November 15th, 2013, 07:35 PM   #19
Tags
meballs
Page generated in 0.29866 seconds with 80 queries
