tj heat/ac issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2013, 05:13 PM   #1
Zach4739
2005 Willys
Zach4739's Avatar
Default tj heat/ac issue
i have an 05 tj with 15,000 miles on it.
the direction of the heat or air dosnt work it blows out the same vents no matter what setting its on.
this a common problem? i can hear the vacuum working when i change settings but it dosnt do anything
help! my feet get cold
Zach4739 is offline   Reply With Quote
Old October 15th, 2013, 05:59 PM   #2
xjmichigan
xjmichigan's Avatar
Blend door most likely broke and it defaults to defrost position.
I replaced mine (06 tj) by removing the dash
Old October 16th, 2013, 10:12 AM   #3
Zach4739
2005 Willys
Zach4739's Avatar
well its stuck on the vents that blow right at my face.
i was hoping i wouldnt have to pull the whole dash apart but i guess that gona have to happen. thanks boss
Page generated in 0.19984 seconds with 32 queries
