XJ: Put a cam in a renix 4.0 now it won't start... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 15th, 2013, 12:18 PM   #1
snocross2xtremes
snocross2xtremes's Avatar
Default Put a cam in a renix 4.0 now it won't start...
Bought a 90 xj with rebuilt 4.0 that had a bad cam lob. Ran when I picked up.
Confirmed that cam was Bad. then Ripped it apart and put a new stock cam in it.
Put the motor at tdc and reinstalled distrusted.
Motor has spark and 50psi of fuel pressure.
Any ideas??
Old October 15th, 2013, 12:20 PM   #2
WACKO1
2000 xj
WACKO1's Avatar
time off on cam
WACKO1 is online now   Reply With Quote
Old October 15th, 2013, 12:20 PM   #3
firehawk
Live Action!
firehawk's Avatar
Recheck the timing. Could be 180 off.
Old October 15th, 2013, 12:34 PM   #4
Dylan
Dylan's Avatar
this. TDC has 2 spots. people miss this. You need to be TDC compression stroke cyl 1 before you set the distributer.
Old October 15th, 2013, 12:55 PM   #5
snocross2xtremes
I watch the intake valve close as I brought it to tdc.
Old October 15th, 2013, 12:57 PM   #6
firehawk
Live Action!
firehawk's Avatar
Does it try to start?
Try starting fluid?
Old October 15th, 2013, 01:10 PM   #7
Tom
Because racecar
Tom's Avatar
You put something together wrong would be my guess.
Old October 15th, 2013, 01:27 PM   #8
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Old October 17th, 2013, 09:16 AM   #9
WACKO1
2000 xj
WACKO1's Avatar
if you lined up the timing marks on the cam and crank you are off. by 180
Old October 20th, 2013, 04:04 PM   #10
snocross2xtremes
After market timing chain set. You had to line the square up with the dot. Not the dot to dot. Who would of guessed?
Tags
meballs
Page generated in 0.28862 seconds with 53 queries
