expanding foam spray insulation local sources? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 14th, 2013, 11:57 AM   #1
kickstand
circling the drain
kickstand's Avatar
Default expanding foam spray insulation local sources?
I'm looking for some sort of spray on foam insulation similar to what you see on the bottom side of a hot tub.
Does anyone know where something like this could be purchased? I'm having a hard time finding a local source.
kickstand is online now   Reply With Quote
Old October 14th, 2013, 12:06 PM   #2
Bones
Bones's Avatar
for what purpose? how much sq feet?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 14th, 2013, 12:14 PM   #3
BlooMule
Old School
BlooMule's Avatar
This is the only stuff I'm aware of at the consumer level.
http://www.homedepot.com/p/GREAT-STU...9#.UlwX3VP-vFI
When they insulated the shop the company that did it had special equipment to spray it. They were also wearing what looked like hazmat suits.
-rw-rw-rw
Old October 14th, 2013, 12:18 PM   #4
kickstand
circling the drain
kickstand's Avatar
Insulate wood burner water tanks.
Approximately 65-75 square feet. (3' diameter tank x 6-7 feet long)
Home depot used to carry larger kits, but you have to purchase a lot of equipment to apply (According to stupid sales guy who said they no longer carry what I wanted), not necessarily worth it for a one time application.
Old October 14th, 2013, 12:21 PM   #5
BlooMule
Old School
BlooMule's Avatar
At $4 a can, might be worth it to just use the Great Stuff.
-rw-rw-rw
Old October 14th, 2013, 01:17 PM   #6
Are the tanks outside or in some kind of enclosure? Maybe better to insulate an enclosure with rigid panels of styrofoam. I don't know that the spray on stuff likes to be exposed.
I have seen them mix that stuff up on mythbusters from liquids, its pretty nasty stuff. I know its one of the most expensive options out there for insulating a building.
Old October 14th, 2013, 01:20 PM   #7
kickstand
circling the drain
kickstand's Avatar
Tanks are in a small sided building, anywhere from 6-12" between the tanks and the siding.
I thought about insulating the sides of the building but there is still plenty of area for drafts and such as its not a fully sealed enclosure.
I may turn to the great stuff at $4 a can. Depends on how well it can handle the heat of the tank/water
Old October 14th, 2013, 01:24 PM   #8
Or get creative, and make a shell with rigid sheets of 2" foam, and use the great stuff as glue to hold them and seal them up.
Old October 14th, 2013, 01:47 PM   #9
firehawk
Live Action!
firehawk's Avatar
I found the real reason Chad needs the expanding foam.
Seems to be a drug dealer selling drugs to his family and he ain't havin it.
http://www.topix.com/forum/city/rich...9MBAPK59J8U01O
Old October 14th, 2013, 01:53 PM   #10
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Instead of great stuff you can get the 2 part that comes in what looks like propane cylinders. In Grand Rapids acme insulation would probably carry it. I would look for any wholesale supplier for piping insulation. I'm not sure what is in your side of the state. Depending on who you deal with I can probably get a better deal. You can also use the hilti head and the larger spray foam cans which is better than great stuff. I'm not sure about the heat rating for foam though, fiberglass or a high temp bead insulation may end up being a better bet.
Old October 14th, 2013, 02:00 PM   #11
chadcooper55
If you are going to use a closed cell insulation like foam board I would wrap it in flex clad and aluminum foil tape the seams. In the off season if moisture gets in there you could have rust issues. I would either completely seal it with zero possibility of leaks in the vapor barrier or use some type of open cell insulation and no vapor barrier and use the shelter to keep direct moisture off it. That is just my .02 though...
Old October 14th, 2013, 02:00 PM   #12
BlooMule
Old School
BlooMule's Avatar
Spray foam is flammable, not sure what the flashpoint is.
-rw-rw-rw
Old October 14th, 2013, 02:05 PM   #13
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
theres a place at grand blanc and linden rd
Old October 14th, 2013, 02:10 PM   #14
kickstand
circling the drain
kickstand's Avatar
I asked you the name 100 times butthole.
Old October 14th, 2013, 02:11 PM   #15
kickstand
circling the drain
kickstand's Avatar
This is what I am looking for. I don't trust the jack in the box's at home depot to spend a few hundred dollars on something they seem to know nothing about, so I am trying to find a place locally where I can make sure I have hwat I need to complete the project.
Old October 14th, 2013, 02:14 PM   #16
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
30 seconds on Google said that is
Don's Insulation & Construction
4490 W Grand Blanc Rd, Swartz Creek, MI ‎
(810) 655-4645 ‎
Old October 14th, 2013, 02:32 PM   #17
kickstand
circling the drain
kickstand's Avatar
(810) 655-4645 ‎
Thanks
Old October 14th, 2013, 08:09 PM   #18
Tizken
Menards also sells the dow froth paks, two tanks that mix at the gun. It's quite a bit less expensive than the great stuff per cubic foot, the size they stock is 200 board feet.
http://www.menards.com/main/paint/ca...330-c-7937.htm
Tizken is offline   Reply With Quote
Old October 14th, 2013, 08:10 PM   #19
GerkTJ
GerkTJ's Avatar
menards has kits for commercial use only lol
GerkTJ is offline   Reply With Quote
Old October 14th, 2013, 08:34 PM   #20
hondadirtracer
Skymaster
hondadirtracer's Avatar
FIRE PROTECTION
FROTH- PAK foam is combustible
and will burn if exposed to open flame
or sparks from high-energy sources.
Do not expose to temperatures above
240F (116C).
hondadirtracer is online now   Reply With Quote
Page generated in 0.44767 seconds with 82 queries
