Smoking recipes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 13th, 2013, 11:18 PM   #1
tweak177
Say what?!?
tweak177's Avatar
Default Smoking recipes
Post them up.
I'm interested in smoking. I currently have a Char Griller grill, I'm looking into getting a smoke box for it. What are you techniques? From what I have read and watched, I should keep the temp between 225 and 250 for a big chunk of meat, but what about some fish?
What are your guys recipes?
One of my coworkers brought in some Salmon he smoked with cherry wood and it was delicious. And I'm not a fish guy.
tweak177 is offline   Reply With Quote
Old October 14th, 2013, 08:15 AM   #2
ajmorell
ajmorell's Avatar
Smoke time, temperature and wood type depends on what's being smoked. I actually prefer to cold smoke some things like ribs.
Old October 14th, 2013, 08:23 AM   #3
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
FYI, if you smoke in your BBQ you will ruin it in no time. I did the same thing, use my BBQ for smoking. It worked great as a smoker, but because of the drippings, when I went to use it as a BBQ again, look out grease fires! I tried everything and nothing worked to get the grease out. I tried powerwashing, letting it burn, ect. I finally had to buy a new BBQ. If you care about your bbq, don't use it as a smoker. As far as temps go..I run anything from 200-250 depending on what I'm smoking
Old October 14th, 2013, 08:35 AM   #4
Why YJ?
Don't be a wuss... HIT IT
Why YJ?'s Avatar
x2
I ruined my grill 2 years ago doing this. Buy a dedicated smoker.
2005 LJ comp cut, 1 tons, etc...
Paul
www.teamhodges.com
Why YJ? is offline   Reply With Quote
Old October 14th, 2013, 08:50 AM   #5
kickstand
circling the drain
kickstand's Avatar
I have been using my bbq as a smoker for the last couple of years and don't have any of the aforementioned problems.
My bbq is a peice of shit to begin with, but I don't have any grease fire problems.
That said I like to smoke chicken, pork, ribs, etc. My favorite is a big ass pork loin wrapped in bacon smoked over applewood. 6-8 hours at 225*
Old October 14th, 2013, 09:05 AM   #6
hase
hase's Avatar
So having recently bought a dedicated smoker, I have a bit of info for you.
1. a great resource is http://www.bbq-brethren.com/forum/forumdisplay.php?f=5
2. If you need a starting point idea of time / temperature http://meatsmokingcalculator.com/
3. I have tried alot of these and they are very good... https://www.google.com/search?q=alto...t=firefox-beta
4. the smoker that I got: http://www.motogrrl.net/meatking/index.htm
He is down in Dearborn and makes them to order.
hase is offline   Reply With Quote
Old October 14th, 2013, 12:07 PM   #7
BOGDOG
BOGDOG's Avatar
I just smoked a duck stuffed with quail over a mix of hickory & crabapple. Eating some of it for lunch right now, the duck is great and the quail are even better.
Old October 14th, 2013, 03:11 PM   #8
ChoCha
ChoCha's Avatar
Originally Posted by tweak177 View Post
Post them up.
I use the same Char Griller gas grill with side fire box set up... Ive used it for 3 years this way and have no issues with using my gas grill when I need it.
Key is to use a large foil pan or something to catch the drippings so they dont make a mess of the grill.
Ive made several briskets, turkeys, pork etc and they turn out great. Low and slow is the key. Different woods are fun to play with too, my preference is Cherry or Apple wood. Ive got a few different recipe books at home I got from Bass Pro or somewhere like that. I think one is called Smoke n Spice if I remmeber and it has some good recipes in it.. Even good sides.
ChoCha is offline   Reply With Quote
Old October 14th, 2013, 04:33 PM   #9
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
I have the same one and use it as both a smoker and a grill with no problem. i mostly do brisket and ribs. Never tried fish.
Old October 14th, 2013, 05:15 PM   #10
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I smoke with the same grill I use for BBQ. Never had an issue with grease fires or anything. I use a drip pan below the meat generally so that catches most of the grease anyways. If it is getting sooty and shitty inside chances are you aren't opening your top damper enough. That also makes the food taste sooty and bitter.
Old October 14th, 2013, 11:14 PM   #11
tweak177
Say what?!?
tweak177's Avatar
I have a Char Griller charcoal grill and really didn't see an issue using it as a smoker as long as I had a drip pan big enough to catch the drippings. Still not sure if I'll use it or just buy a smoker though.
Old October 14th, 2013, 11:16 PM   #12
Christmas Cookie
huge grease fires that would burn for hours!!!! I cannot clean it good enough, I kept getting fires everytime I tried to BBQ...junked said bbq and bought a new, problem solved
Page generated in 0.67928 seconds with 58 queries
