Need Help With a Wheel I'm looking at - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 13th, 2013, 08:11 PM   #1
Hooperdog
OllllO
Hooperdog's Avatar
Question Need Help With a Wheel I'm looking at
what are these off of and will they fit my 94 Regular cab 4x4?
thanks
Got em, the fronts fit, will check rear tonight.
Hooperdog is offline   Reply With Quote
Old October 13th, 2013, 08:21 PM   #2
peppy
peppy is offline   Reply With Quote
Old October 13th, 2013, 08:30 PM   #3
1 ton tj on 40's
1 ton tj on 40's's Avatar
cant tell pic's to small
Old October 13th, 2013, 08:34 PM   #4
Hooperdog
OllllO
Hooperdog's Avatar
Originally Posted by peppy View Post
Look like 6 lug so NO
what do you mean no 6 lug is what they have on them!
They are said to come off of a 98 Toyota but he doesn't know exactly what? I'm am going to buy them if I can figure out if they fit. I think they will.
Old October 13th, 2013, 08:39 PM   #5
peppy
Old October 13th, 2013, 08:43 PM   #6
cerial
Direct Drive FTW
cerial's Avatar
Pull off your wheel and check bolt circle and back spacing. Then call X and have them check the same to avoid wasting his time.
Old October 13th, 2013, 08:49 PM   #7
Hooperdog
OllllO
Hooperdog's Avatar
Ford rangers are 5 on 4.5.
A 98 toy is 6 on 5.5
So no they will not fit unless you have Toyota axles
posted in the Toy tech because I have a Toyota truck, 1994 WTF, yes 6 lug on mine just like most of the toyotas, thought someone on here might recognize the rims and say ya off of Tundra or a 4 runner or whatever it is.
The guy gave me some overall dimensions but I can't measure mine until tomorrrow night.
just updated the picture. Thanks.
Old October 13th, 2013, 08:54 PM   #8
peppy
Originally Posted by Hooperdog View Post
posted in the Toy tech because I have a Toyota truck, 1994 WTF people, yes 6 lug on mine just like most of the toyotas, thought someone on here might rcognize the rims and say ya offofTundra or a 4 runner.
Wow my bad I really need to get more sleep! They look like what cam stock on a 98 you just have to double check back spacing
Old October 13th, 2013, 08:57 PM   #9
Hooperdog
OllllO
Hooperdog's Avatar
thanks that what I am wondering too, mine has drums on rear, not sure what the 98 had..
Old October 13th, 2013, 08:57 PM   #10
Toyfish
Toyfish's Avatar
Well they for sure look like toyota wheels to me i couldnt tell you if they r off a 98 or not but i dont see why they wouldnt work on your truck.
Sent from my DROID X2 using Tapatalk 2
Old October 13th, 2013, 09:02 PM   #11
peppy
They came on 98 Tacoma picks with the offload package. I don't think you will run in to a problem with them fitting. Back spacing my be a little different but I don't see it be to much.
Old October 13th, 2013, 09:07 PM   #12
Hooperdog
OllllO
Hooperdog's Avatar
my truck is at the shop and my tires are too bad to drive it to where the wheels are other wise I would do that. This is what the guy text me but I think I need to send him a picture with tape measure on a wheel.
rim 3.5
farthest lug hole across from each other 5.75
lug nut 2.75
inside rim 14.5
lug to outside of rim 4.5
I'm trying to make sense of it.
Old October 14th, 2013, 07:39 AM   #13
timbercruiser
those look like what I had on my 96 Tacoma. They *should* fit on Toyota 6 lug trucks.
timbercruiser is offline   Reply With Quote
Old October 14th, 2013, 09:56 AM   #14
Hooperdog
OllllO
Hooperdog's Avatar
thanks for all the reply's
Old October 14th, 2013, 11:15 AM   #15
BOGDOG
BOGDOG's Avatar
Those are from a Taco or 4Runner they are probably a 16" rim and they do have the same bolt pattern you need.
Old October 14th, 2013, 01:11 PM   #16
Hooperdog
OllllO
Hooperdog's Avatar
they are 15's
Old October 15th, 2013, 11:18 AM   #17
BOGDOG
BOGDOG's Avatar
Yeah now I looked at the tire. All the ones I've seen like that were 16's from 4Runners.
Old October 15th, 2013, 12:23 PM   #18
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
They are off a tacoma or 4runner.....they will fit fine
Old October 15th, 2013, 12:59 PM   #19
Hooperdog
OllllO
Hooperdog's Avatar
Picking up tomorrow thanks. Now I need a tank.
Old October 17th, 2013, 11:25 PM   #20
Rattler
Home Sweet Homicide
Rattler's Avatar
They will fit fine. They will fit a Chevy 6-lug fine too. You only need to worry about them being 15s if you are running Tacoma brakes.
Page generated in 0.36929 seconds with 83 queries
