CTM U Joints... - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 8th, 2013, 08:14 PM   #21
Yeah but they aren't following the Jantz design anymore. His patent was for the spring plungers in each trunion & they discontinued doing that because people struggled assemebling them. Personally I think they are a great design and his R&D process was priceless. (have you ever read it?)
I read his thread on pirate about patenting using a coating on the inside of the caps as a bearing material Iirc. AlTiN I believe.
Old October 8th, 2013, 08:43 PM   #22
There's more to it. When he was experimenting with different lubricants, he got very creative. I have an email from him on my work computer that is pretty interesting. I'll dig it up tomorrow.
Old October 8th, 2013, 09:38 PM   #23
liv2mx
i like jungle gym's.
liv2mx's Avatar
Spicer non greasable are the best if your on a budget hands down. Or like tab said all the higher money ones are awesome.they will last longer then most shafts.
Old October 8th, 2013, 09:41 PM   #24
Bones
Bones's Avatar
CTM and Superior shafts. 40" stickies and a rough life. Never had an issue. Spent the money once and never regretted it.
you will have to buy rebuild kits every year if you wheel a lot at faster speeds though.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old October 8th, 2013, 10:03 PM   #25
benny87
Young Gun..!
benny87's Avatar
nitros 300M ones suck, you need to grease them after EVERY run..
Went to Yukon super joints with my shafts.
benny87 is offline   Reply With Quote
Old October 9th, 2013, 06:19 AM   #26
Here is the article from Jantz on Pirate: It summarizes why Nitro's suck ass amonst other things.
http://www.pirate4x4.com/forum/gener...copy-cats.html
Old October 9th, 2013, 06:20 AM   #27
Good luck getting a superior shaft warrantied anymore if you have issues. I went the same route but even the person I bought my superiors from says he hasn't been able to get anything warrantied in over a yr.
Old October 9th, 2013, 06:29 AM   #28
benny87
Young Gun..!
benny87's Avatar
Nice... Well I am glad that I changed out my joints. They are in the spare shafts now.
Old October 9th, 2013, 08:55 AM   #29
ReiKo
Community Smart Ass.....
ReiKo's Avatar
Anyone ever tried these OX Locker ones?
Just curious to hear feedback on them...
ReiKo is offline   Reply With Quote
Old October 9th, 2013, 09:12 AM   #30
Complete Off Road
Complete Off Road's Avatar
I do believe Superior has gone out of business
Complete Off Road is offline   Reply With Quote
Old October 9th, 2013, 09:20 AM   #31
Yeah, luckily I bought from Andrew @ letzrolloffroad.com and he will still warranty any domestic shaft he's sold which includes my superiors. With 38.5" LTB's I don't think I'll see the day I need to do that anyway
http://www.pirate4x4.com/forum/gener...-business.html
Originally Posted by jpcrawleram View Post
Can't speak for ecgs but we still cover warranty of any domestic shaft. Same as it always was. Obviously bought from me.
I'm sure chase (ecgs) I similar.
Old October 9th, 2013, 09:45 AM   #32
Bones
Bones's Avatar
as mentioned above, it depends more on who you buy them from...
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Old October 9th, 2013, 10:44 AM   #33
Here is an email I received from Carl Jantz several years ago. It was cut & pasted from some of his early literature. I found it entertaining how he did his testing, which I have highlighted.
Iíd just like to set the record straight for those who think the Yukon super joint is just a cheap copy of other extreme joints on the market today. I have been working on a better U-joint since I broke my 1st front axle U-joint in 1978. After trying every brand, I eventually used Spicerís, but in the old bronco they were the 260x joints, eventually as tires got bigger and several U-joints later, I stumbled on the fact that some Dana 44s used 297x (now 760x) u-joints and bored out my axles to fit. Then of course the ears tore off or stretched, so I built them up with a stick welder and 7018 welding rod. This worked very well for years, then along came still bigger tires and extreme 4 wheeling. I looked at modifying Dana 60 crosses to fit into the D44 caps around 1985 but decided no one would be willing to pay the price of buying 2 U-joints and then machine work to make them work, plus brass bushings that would eventually deform under the extreme pressure exerted upon them. (I didnít know about beryllium bronze at that time). So I built my 1st Dana 60 5 lug front (1986) end and went happily 4 wheelin with 18/44ís for years. Then I went to the 1st NWRCA rock crawl at Vantage Washington and realized that there was a real need for a stronger joint and that a few people would be willing to pay for them. By this time I had worked a Boeing in R & D and had worked with Ionic coatings to drill through Titanium. I figured if It made the drills last significantly longer and since NASCAR was using Ionic coatings on the ring and pinions with great success to reduce friction that they might work on the u-joint crosses to avoid using a bearing. To learn more about Ionic coatings to go to www.Ionbond.com. (Note Ford Model A cars used no needle bearings in their U joints, just 140wt grease and hardened caps on hardened crosses, but then they were only dealing with 40 hp.)
So I had a drill bushing company make some 4340 hardened bushings for me that press fit over the 297X crosses and fit into the caps to replace the needle bearings, and then set up a design of experiments to test various greases and Ionic coatings.
I first used one grease with several coatings to find the best Ionic coating. Then I used one Ionic coating to test several greases. The last test went something like this. Installed 2 Joints into front end of diesel suburban with 4 kinds of greases, one type of grease in 2 caps. Then I pulled out the rear drive line and with my jeep on the trailer behind the suburban went on a 1200 mile road trip including Stevens pass, Snoqualmie pass and White Pass. (Getting started in front wheel drive was a pain sometimes) I then inspected the joints and found out two things. All of the greases were just fine, AND there was water in the joints. Now this was all highway driving in 70 plus weather except one Ĺ hour rain storm, I figured out that as the cold water sprayed up on the u-joints they cooled down creating an internal suction that pulled the water inside the joints, hence they now have pressurized grease reservoirs.
So on to finally test the greases, I chained the rear end to a tree with the front end on dry pavement, and burned a set of tires to the cords in 45 minutes of smoke. All the greases failed except one, and it looked just like I had just assembled the joint and never tested it at all. The grease is an Aircraft spec anti-seize. All automotive greases, even the synthetics never even came close to this stuff.
So with parameters set it was time to combine all factors and do a real world test. 16 joints were made from billet and tested at Cedar City in the April of 2002 at the U-roc crawl. There were no failures and, all of the rigs using the joints placed in the top ten at the event. So onto production, attaining a patent and working with a distributor, and now they are finally here.
Old October 9th, 2013, 11:04 AM   #34
ReiKo
ReiKo's Avatar
What's the name of the grease? I'm all ears since I run Mobil 1 grease on everything...
Old October 9th, 2013, 11:47 AM   #35
copper high heat anti seize
Page generated in 0.67952 seconds with 68 queries
