Misc Jeep Part(s) CraneCam model 753901 for Jeep 232/258ci - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2013, 09:25 PM   #1
rcracer
Up......And.......Over
rcracer's Avatar
Default CraneCam model 753901 for Jeep 232/258ci
I bought this used, about 5k miles. Asking $65
Part Number: 753901 Grind Number: H-260-2 (REPLACES HMV-260-2)
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1964 Up AMERICAN MOTORS 6 SMOOTH IDLE, DAILY USAGE, OFF ROAD, TOWING, ECONOMY, ALSO MILD TURBOCHARGED, 2200-2600 CRUISE RPM, 8.0 TO 9.5 COMPRESSION RATIO ADVISED. BASIC RPM 1500-4500
Engine Size Configuration
243-258 C.I.
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 2847 @Valve 456 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3027 @Valve 484
Rocker Arm Ratio 1.6
CamTiming: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 19 BTDC 61 ABDC 260
Exhaust 69 BBDC 23 ATDC 272
Spring Requirements: Triple Dual Outer Inner
Part Number 99833
Loads Closed 95 LBS@ 1.700 or 1 45/64
Open 247 LBS@ 1.240
Recommended RPM range with matching components
Minimum RPM 1500
Maximum RPM 4500
Valve Float 6500
CamTiming: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake (5) ATDC 29 ABDC 107 204
Exhaust 45 BBDC (9) BTDC 117 216
Remarks:
rcracer is offline   Reply With Quote
Old October 9th, 2013, 05:33 PM   #2
rcracer
rcracer's Avatar
open to possible trade/cash for VW parts or 31x12.5 pair of tires.
Page generated in 0.19335 seconds with 30 queries
