Dana 60 knuckle upgrades - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 7th, 2013, 09:19 AM   #1
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
Default Dana 60 knuckle upgrades
Currently running a 78-79 spec Ford 60 with plated stock knuckles and no high steer. I wanna upgrade the knuckles and go to highsteer.
I know most will say just buy Reid stuff and be done but i'm thinking of going a different direction. I am thinking of picking up a cheap super duty 50 and putting everything from the inner C out on my axle and having Rock Solid work their magic on the outer knuckles. In my opinion after seeing this setup side by side with the reid king pin knuckles it looks just as beefy and i like the simplicity of the unit bearings. If i can score a donor axle cheap the overall cost will be way less than reid stuff also.
Thoughts?
Old October 7th, 2013, 09:21 AM   #2
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I well mention i have intentions of getting inner c's and knuckles if i stay kingpin so either way i will be cutting the stock c's off
Old October 7th, 2013, 10:10 AM   #3
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
Rsp has done an awesome job with the unit bearing outers. I just bought back the axles from my old buggy project. The front is a 99-04 60 with all the Rsp goodies on the outers. I haven't ran them yet but I definitely have no complaints about the quality that they put out. The machining is perfect on the knuckles for high steer. The arms don't slide on easily but you don't have to beat them on either. Just a few taps with a mallet and they are on with zero wiggle before you even put the bolts in. I also had them drill the unit bearings to 8 on 6.5 and machine them for their smaller brake setup. I also got the caliper bracket for the smaller brakes. They are great guys that put out a top notch product.
Old October 7th, 2013, 10:12 AM   #4
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
I am aware....my buddy has their full setup on his super duty 60 and i was highly impressed by it.
Old October 7th, 2013, 10:44 AM   #5
liv2mx
i like jungle gym's.
liv2mx's Avatar
Make sure whatever you get the high steer is keyed.I have eorp billet knuckles and I'm very happy.I just broke the kingpin off and the knuckles are fine.rsp has good stuff.i also like the unit bearing.there is a bunch of people making some sweet knuckles out there now also.
Old October 7th, 2013, 11:32 AM   #6
benny87
Young Gun..!
benny87's Avatar
I like my cranes. Nice to be able to weld to the knuckle to make the high steer arm double shear.
benny87 is offline   Reply With Quote
Page generated in 0.28806 seconds with 41 queries
