Barnes 4WD Universal 3 Link Kit - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old October 4th, 2013, 11:50 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default Barnes 4WD Universal 3 Link Kit
All Kits ship with brackets pre-drilled to the correct bolt hole size and no extra cost!
This is the kit that has all the parts that we are always using in the shop for customers three links suspensions. Our kits are built to stand up to the abuse that rock crawlers, weekend warriors, and daily driven rigs see. This kit includes:
1 x Axle Link Mount Pair 10 Deg
1 x Frame Link Mount
1 x Adjustable Inner Frame Link Mount Pair 0 Deg
1 x Link Tower
1 x Outside Frame Panhard / Trackbar Mounting Bracket
1 x Offset Axle Panhard Bracket
1 x Chromoly 3/4 - 16 X 3/4" Heim RH
1 x Chromoly 3/4 - 16 X 3/4" Heim LH
2 x High Misalignment Spacer - 3/4" to 5/8" (pair)
1 x 3/4" - 16 Jam Nut RH
1 x 3/4" - 16 Jam Nut LH
1 x Tube Insert (3/4-16) 1" ID Tube RH
1 x Tube Insert (3/4-16) 1" ID Tube LH
3 x Chromoly 1 1/4"- 12 X 1" Heim RH
3 x Chromoly 1 1/4"- 12 X 1" Heim LH
6 x High Misalignment Spacer - 1" to 5/8" (pair)
3 x 1-1/4" - 12 Jam Nut RH
3 x 1-1/4" - 12 Jam Nut LH
3 x Tube Insert (1-1/4-12) 1 1/2" ID Tube RH
3 x Tube Insert (1-1/4-12) 1 1/2" ID Tube LH
Barnes 4wd is offline   Reply With Quote
Old November 18th, 2013, 12:42 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
Jeremy sent us in a picture of his Jeep, he used our universal 3 link front kit, and 4 link rear kit.
Enduro joint 4 link rear suspension kit
Enduro joint 3 link front suspension kit
Old May 14th, 2014, 10:04 PM   #3
Barnes 4wd
Barnes 4wd's Avatar
Besides our Universal 3 link kit, we also offer a couple of different varieties of 3 and 4 link kits. Including single and double triangulated 4 link kits. Our kits also are available with Enduro Joints or Chromoly heims. If you have any questions about substitutions let us know and we will make sure the kit is perfect for your application!
Find all our 3 and 4 link suspensions HERE.
Old October 13th, 2014, 10:37 PM   #4
Barnes 4wd
Barnes 4wd's Avatar
Our Universal 3 link kit comes with either Heim Joints, or Enduro Joints. Give us a call or email if you have any questions or need help deciding what kit is right for you.
Old May 6th, 2015, 01:18 AM   #5
Barnes 4wd
Barnes 4wd's Avatar
Congratulations to Chris May on his win this past weekend at the Dirt Riot race at Gray Rock in Olive Alabama. Chris is running our four link, three link and a ton of other parts. It is always great to see your products winning!
Thread Tools
Page generated in 0.17187 seconds with 38 queries
