feeler 2001 tj sahara gm ls supercharged - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 1st, 2013, 12:44 AM   #1
scotte
Default feeler 2001 tj sahara gm ls supercharged
putting out a feeler on my 2001(iirc it may be a 2000) tj sahara green w/ tan/green seats has ~110k on it
i bought it after it had been in an accident and i fixed it (new frame and front end parts)
frame was coated in por-15,all new brake lines (the poly armour stuff that wont rust)
dana 44 rear (factory option) dana 30 front both have 4:10 gearing
and air powered ox lockers front and rear (the new design with the cylinder built into the cover
rubicon express 4" lift kit
bilstein 5100 polished body shocks front and rear
adjustable upper arms front and back
adjustable front track bar
heavy duty front lower arm mounts
polished aluminum wheels with 33x12.5 wrangler duratracs on them including spare
rebuilt 231 with sye and cv rear driveshaft
nv3550
gm 4.8 ls v8 with ls9 cam,hardened pushrods,beehive valve springs
liquid intercooled magnacharger kit producing 10psi
tuned with hptuners custom 2 bar os
motor is 450-500hp
aem wideband and autometer boost gauge installed
stainless 3" exhaust
factory gauges are all there and all work using the stock pcm as a gauge mule with a novak tach emulator for the factory tach
aftermarket front bumper,rock sliders,rear bumper with spare tire carrier and fuel can mount all powdercoated tan
i have attached a engine bay pic and a pic i took before i got the bumpers/sliders back from the powdercoat shop
body has a small amount of rust just starting on the back of the tub in the normal 2 spots
just a feeler probably going to sell it either before winter or i'll store it and put it up for sale next spring
was thinking of asking $17,500 for it
the blower kit alone was $7000 new
ID:	110902   Click image for larger version
scotte is offline   Reply With Quote
Old October 1st, 2013, 08:45 AM   #2
gtospeeding
nice build.
How many miles are on the body and motor? What year is the motor and tc ?
How is the stock 5 speed holding the blower?
gtospeeding is offline   Reply With Quote
Old October 1st, 2013, 10:07 AM   #3
prostock3
gimmie gimmie more
Send a message via AIM to prostock3
sweet setup its like a SRT8 Wrangler
prostock3 is offline   Reply With Quote
Old October 1st, 2013, 06:04 PM   #4
scotte
Originally Posted by gtospeeding View Post
nice build.
motor has ~115k on it (installed n/a with ~107k on it, installed cam pushrods and valvesprings at time of installation into jeep) driven for ~5k na and i have put ~3k on it since installing the magnacharger
by tc i assume you mean transfer case
its an 01 with a new chain/bearings/oil pump and sye at time of build
stock 5speed is holding good
i'm sure i could destroy it if i tried
i don't do clutch dumps and power shifts
not saying it couldn't take it but id rather throw it in a gear and then apply the power
rev limiter on the 4.8 is set at ~6500 and
3rd or 4th gear can get you scary fast quick
Page generated in 0.25758 seconds with 36 queries
