90 318 black smoke, runs rich.... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 7th, 2006, 11:43 PM   #1
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Default 90 318 black smoke, runs rich....
My grandpa has a 90 with a 318. He was pulling his boat home from up north a few weeks ago and the truck started using fuel like crazy. 1/4 tank in about 20 miles.
He got it home and did the regular plugs, cap, and rotor thing, but it's blowing black smoke out the tail and running rough, falling on it's face at WOT.
I went down to his house tonight for a few hours to help. No codes, TPS tested fine, fuel pressure reg is fine, timing is fine, etc...
The injectors don't have a nice mechanical click and they are just dumping fuel into the TB.
Any ideas for him? I am not sure if a bad o2 sensor will cause the PCM to just dump fuel... but I should have tested it.
JcrOffroad
Zoom Zoom!
Old November 7th, 2006, 11:58 PM   #2
nixxerRsixxer
Homewrecker
nixxerRsixxer's Avatar
clogged cat? .. causing sensor to dump fuel? ..
nixxerRsixxer is offline   Reply With Quote
Old November 8th, 2006, 06:54 PM   #3
user name
keep your stick onthe ice
user name's Avatar
put a fourbarrel on it.
Old November 13th, 2006, 10:55 PM   #4
user name
user name's Avatar
ok now for a real answer check the map sensor. i dont think those injestors have as much of a click being that they are on four times as long as many newer multi ports. i dont see it being horibly far out if it still runs but it sounds like youve check most of the likely stuff. did you by any chance check back pressure in the exhaust(clogged cat)? if thats the case you can get a no more cat pipe from auto value. i think i got mine from a 78 1 ton heavy duty style cuz cats just plain cost a lot.
Old December 17th, 2006, 03:54 PM   #5
oldoneton
oldoneton's Avatar
put a o2 sensor on it. on the early chrysler fuel injection systems the o2 sensor will stick in a in range lean condition and cause it to run rich. because it's an in range failure it won't set a code. with out seeing the data on a scan tool I can't say for sure but i've seen it happen a lot in the 17 years that i've been doing this.
oldoneton is offline   Reply With Quote
Old December 18th, 2006, 10:25 PM   #6
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
That was the problem. Clogged cat lead to a burned out O2 sensor. I couldn't believe how rich that O2 made it.
JcrOffroad
Zoom Zoom!
Page generated in 0.29653 seconds with 41 queries
