GM 14 Bolt High Clearance Shave Cover from Barnes 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 30th, 2013, 01:09 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default GM 14 Bolt High Clearance Shave Cover from Barnes 4wd
The 14 bolt is a great axle; cheap, strong, easy to find and cheap to build. However they have always had one down fall, that huge lip on the bottom that get hung one ever thing on the trail. Barnes 4WD has come up with a solution to this issue. Our GM 14 Bolt 3/8 Shave Cover, this cover will give you more than 1 of ground clearance. Another thing that makes this a great shave cover is that you will not need to have your gears turned or perform a complicated welding or machining process that just adds more cost to your axle build. All that you will need to do is bolt the diff cover to your axle and cut off the extra lip. This can be done with simple tools that you have and you can do it yourself and we GUARANTEE THEM FOR LIFE!
Like all of our diff covers they are made from 3/8 plate and machined flat after they are welded to insure that you will have a flat surface to mount to your axle. We do recommend using allen head bolts on our GM 14 Bolt Shave Cover. This is made in the USA, from USA steel! Find them online here:
Barnes 4wd is offline   Reply With Quote
Old September 30th, 2013, 01:44 PM   #2
Carbon
Yooper
Carbon's Avatar
How much?
Carbon is offline   Reply With Quote
Old October 1st, 2013, 11:19 AM   #3
Barnes 4wd
Barnes 4wd's Avatar
$120
Old February 8th, 2014, 12:33 PM   #4
Barnes 4wd
Barnes 4wd's Avatar
A cover that one of our customers installed!
You can find our 14 bolt shave cover, and all our differential covers here.
Old February 8th, 2014, 12:38 PM   #5
puckett
puckett's Avatar
I don't feel like searching so I figured I'd ask. Do you make a 8.8 cover and how much?
puckett is offline   Reply With Quote
Old March 7th, 2015, 08:12 PM   #6
Barnes 4wd
Barnes 4wd's Avatar
No 8.8 cover at this time.
Old March 7th, 2015, 08:12 PM   #7
Barnes 4wd
Barnes 4wd's Avatar
Get the most ground clearance out of your 14 Bolt rear axle!
Barnes 4WD 14 Bolt Shave Cover
Thread Tools
Page generated in 0.24966 seconds with 44 queries
