88 wrangler sold sold sold - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 29th, 2013, 07:27 PM   #1
sparkinspecial
sparkinspecial's Avatar
Default 88 wrangler sold sold sold
have a 88 wrangler project for sale. Starting with the body has had new front floor pans installed has rust along edge of floor in the back where it meets the inner wheel wells worse on pass side also has rust on the back corners. Windshield frame and glass are great. Front passenger fender has a little rust. Frame did have some rust but has all been professionally repaired and plated rear shackle mounts where moved under frame like the cjs where very solid. Rear cross member was replaced with integrated bumper. Comes with half hard doors no top. Only has front seats
the motor is the straight 6. 5 speed manual transmission and stock t case are good the rear axle was swapped with one from a 4 banger so it has the 4.10 gears front was all rebuilt with new ring and pinion to match. it runs and drives pretty good mechanically sound. has new front brake pads and passengers side front caliper. just changed the oil and filter. new air filter new coil, new starter relay, and new ignition module, also has a remaned hollry carb and new radiator
Suspension has been converted to spring over axle with 2" lift shackles and add a leafs giving it around 8-9" total lift, all mounts are welded to axles. The rear axle was moved back about 4" started making filler panels as seen in pics so flares could be put back on (rear flares are included). Suspension is still soft and should flex good.
has a nice set of 35" mickey Thompson claws on stock wheels front hit the leaf springs if you turn to tight so need some spacers
make someone a great toy as is or with a little body work and paint a nice dd
NEEDS NOTHING TO GO PLAY RIGHT NOW
has a clear Michigan title
first 1600 gets it
Attachment 110912
Attachment 110913
Attachment 110914
Attachment 110915
Attachment 110916
sparkinspecial is offline
Old September 30th, 2013, 01:00 PM   #2
sparkinspecial
Up
Old October 1st, 2013, 06:38 AM   #3
sparkinspecial
ok new price for one week then I am taking it off the market and finishing it over the winter
first 1600 gets its
Old October 1st, 2013, 07:28 PM   #4
sparkinspecial
new pics and it does come with a rust free tailgate
Old October 2nd, 2013, 05:09 PM   #5
sparkinspecial
up
Old October 3rd, 2013, 10:07 AM   #6
sparkinspecial
Sold off craigslist in one day would of thought it would have sold here first
Page generated in 0.21618 seconds with 41 queries
