Poly Bushings and Bushing Kits from Barnes 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 29th, 2013, 01:40 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default Poly Bushings and Bushing Kits from Barnes 4wd
This is a great kit, made from 2" DOM with a " wall and a high quality poly bushing inner sleeve bore is 9/16" or 5/8 which gives you a very thick wall thickness that will not become egg shaped with hard use. This combo is great for any application that you need to isolate vibrations. These can be used for motor mounts, cage mounts, transmission and transfer case crossmembers and many other applications. Our DOM Sleeve with Poly Bushing comes in two lengths. Like all of our products, they are made in the USA from USA steel.
This is what you need to make that crossmember bulletproof and still vibration dampening, it comes with everything and is made of 2.0" DOM with a .25" wall and .375 Tabs for frame mounting (we can replace with 1.75" or 2.0" Radius Tabs for tube mounting). It comes with 2 grade 8, 9/16" bolts with Lock nuts, 4 high quality Bushings, and an inner Sleeves Cadmium coated. They are 3" wide. Sold in pairs.
Our single poly bushing kit comes with two bushings and one inner sleeve. The inner sleeve has a bore of 9/16" or 5/8 which gives you a very thick wall thickness that will not become egg shaped with hard use. The bushings are designed to fit a 1.5" ID tube.
Barnes 4wd is offline   Reply With Quote
Old January 25th, 2014, 12:13 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
Our poly bushing kits are designed to help you save time when building motor mounts, crossmembers, or just about anything else you can think of!
Old October 19th, 2014, 09:11 PM   #3
Barnes 4wd
Barnes 4wd's Avatar
Poly bushings are a great solution for many different projects you are working on. They can be used for body mounts between a rollcage and frame, on suspensions, for crossmembers, and engine mounts to name a few. These bushings are great for any place you need to isolate vibrations. Like all our products they are made from high quality materials, and 100% USA Steel!
Find them all here.
Old July 3rd, 2015, 02:48 PM   #4
Barnes 4wd
Barnes 4wd's Avatar
We have been offering our DOM Sleeve & Poly Bushing Kit with 2" tubing for quite some time, we just released some new options that use 1.75" tubing. These still use the same thick inner sleeve, but save you some money and weight where it isn't needed.
Thread Tools
Page generated in 0.20851 seconds with 35 queries
