4.0 cooling issues - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 18th, 2013, 04:40 PM   #21
WACKO1
2000 xj
WACKO1's Avatar
Are the fan shield In place ? You have done every thing and can't think of anything else that you can do. My only other though is that the gauge or sensor is bad.also what temp dose the electric fan come on, the only other is to try running with out thermostat. Oh what about the radiator cap is it new ? That can also cause a over heat problem
WACKO1 is offline   Reply With Quote
Old October 18th, 2013, 04:45 PM   #22
yyj87
yyj87's Avatar
Fan in rigged always on, shroud intact and a new cap.
I have a feeling that when I solve this puzzle I'm going to feel like a dumbass. I must be over looking something stupid.
The block is actuly a 96 and the belt is routed properly.
yyj87 is offline   Reply With Quote
Old October 18th, 2013, 04:50 PM   #23
firehawk
Live Action!
firehawk's Avatar
Its a Jeep thing I don't understand.
Old October 18th, 2013, 05:54 PM   #24
WACKO1
2000 xj
WACKO1's Avatar
I will talk to a few people I know at Chrysler and see if they have any ideas
Old October 18th, 2013, 08:06 PM   #25
frdboy
frdboy's Avatar
Sounds like air is getting in the sys., could be a cracked head. If you can find someone with a exhaust 5 gas analyzer.....have them sniff the cooling sys. and look how much HC's (hydrocarbons) are in the cooling sys. should be less than 100 ppm, most good cars are less than 40 ppm. anything over 500 ppm is for sure combustion gases getting in the cooling sys. somehow. I get the analyzer warmed up and running, do a cold start and sniff the resivoir........let it warm up and check it again.....be sure to keep the reservoir closed in-between checks to trap the hc's.
Did the T-stat have a jiggle valve in it? If so cut it out so there is just a hole and if it does not have a hole/valve...drill a 1/8 hole in the stat so air can escape, it will help with the temp swings and let you drive it a while more.
Old October 21st, 2013, 02:40 PM   #26
WACKO1
2000 xj
WACKO1's Avatar
Check belt routing, or the head is cracked, try running with no t.stat and see how it is
Old October 21st, 2013, 07:28 PM   #27
yyj87
yyj87's Avatar
New symptoms... things changed all the sudden today.
The spikes in temp only last a few seconds now, way to fast to be actual temp changes! My heat blows hot intermittently.
Belt is spinning the water pump in the correct direction. The only difference between the yj pump and the zj pump is the bolt paturn in the flange. I cut a notch in the top of the t-stat to leet air pass. We will see if it helps.
Old October 21st, 2013, 07:32 PM   #28
firehawk
Live Action!
firehawk's Avatar
Air pocket.
Old October 21st, 2013, 07:33 PM   #29
yyj87
yyj87's Avatar
I'm shopping for a reman head.....
Old October 21st, 2013, 07:34 PM   #30
yyj87
yyj87's Avatar
Air pocket.
Created by a cracked head or some 4.0l voodoo?
Old October 21st, 2013, 07:41 PM   #31
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
I dealt with temp issues in my sbc in my tj this year. My one bit of advice is don't think that putting a new stat in rules out a thermostat issue. The one that was in the jeep was bad, I put a new one in and that one was bad also. It acted almost the same as the old one. The third one worked like a charm.
They are cheap as hell and easy to install, buy another one and throw it in just to be sure. I had many, many days of frustration with this shit. Good luck!
Old October 21st, 2013, 08:26 PM   #32
yyj87
yyj87's Avatar
I'll grab another new one tomorrow, I too have installed bad tstats.
Old October 22nd, 2013, 07:18 AM   #33
WACKO1
2000 xj
WACKO1's Avatar
run it with out a stat and see if you have problem
Page generated in 0.36655 seconds with 62 queries
