E Cig/Vapor people. WTF is what? - Page 11 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 14th, 2014, 04:59 PM   #201
BadMoonRacing500
Freedom isn't Free
BadMoonRacing500's Avatar
Would this be a good starter kit? I was going to get the 1100 mAh battery and some extra coils?
http://www.desire-ecig.com/eGo-Kange...r-Starter-Kits
BadMoonRacing500 is offline   Reply With Quote
Old January 14th, 2014, 05:00 PM   #202
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
Yeah, it looks good to me. I think just my 1 battery was 29.00... Granted my battery is much more than those batteries.
Old January 14th, 2014, 05:07 PM   #203
Jiveturkey3
Jiveturkey3's Avatar
Originally Posted by MonkeyBiz View Post
My Ego-cTwist *1200mAh (IIRC)* goes up to 4.8v.
I went with ego-t batteries to start as the person I know who vapes uses these and is having good luck. The clear-o-mizers I ordered are 2.4-2.9 ohms. I think I'm light of volts with this set up. I didn't like the twist because as far as I can tell you don't know how many volts its putting out without an inline meter. The big batteries with a digital display are to expensive until I know if this will work for me to quit smoking. Also they seem huge and I want it to fit in my pockets which already have too much shit in them, although they won't have a pack of cigs or lighter soon so maybe they would work.
How do you know how to set the twist correctly to match the ohm of your clear-o-mizers. I ordered vision ego ones.
Jiveturkey3 is offline   Reply With Quote
Old January 14th, 2014, 05:47 PM   #204
BadMoonRacing500
Freedom isn't Free
How about a few of these
http://www.ebay.com/itm/Kanger-T3s-C...item3f2ea62e07
and this
http://www.fasttech.com/products/1411/10007241/1489902
Old January 14th, 2014, 06:00 PM   #205
89Laredo
89Laredo's Avatar
Send a message via Yahoo to 89Laredo
Originally Posted by Jiveturkey3 View Post
With the law of ohms wouldn't you want higher than 3.7v for 2.2 ohms?
Dont know the "science" behind it, just know it works. lol
In this case Higher resistance=less heat (kinda backwards sounding, I know)=longer lasting coil
If you get a coil that has too little resistance it gets too hot and you will get a burnt taste, your coil will also burn up quick.
I was worried the 1.8 would get too hot with thick VG juices (doesnt flow into teh coil as easy), and I have noticed that if I take too quick of a draw it does taste a little burnt. Its easy to take a quick draw with the T3S, its "airy" (which I dont really like). Hoping the 2.2 ohm takes care of that.
Voltages are marked.
All I want to do is smoke meth, fuck my sister, and hang myself with a belt.
89Laredo is offline   Reply With Quote
Old January 14th, 2014, 06:05 PM   #206
89Laredo
89Laredo's Avatar
Originally Posted by BadMoonRacing500 View Post
Not a bad deal on the T3S, I get mine from here http://www.thevaporroom.net/nkat3segobcc1.html
Replacement coils: http://www.thevaporroom.net/kat3srecoun.html
BUt shipping is like 4 bucks, so I usually order at least 4 things at a time (juice and carts, etc.)
Dont knwo anything about the battery
Old January 14th, 2014, 06:15 PM   #207
Jiveturkey3
That's the first I have seen that they are marked. Couldn't find that info but I'm new to all of this.
The law of ohms is add 2 and its your volts needed. So 2.9 ohms needs 4.9 volts as an example.
Old January 14th, 2014, 07:37 PM   #208
89Laredo
89Laredo's Avatar
swapped to the 2.2 coil. More vapor and better flavor with this stuff 100% VG "Smores" liquid. 2.2 ohm/ego T seems to be the right combination for me.
Old January 14th, 2014, 07:39 PM   #209
Jiveturkey3
With no PG I assume you weren't a smoker? My understanding is PG give you the throat hit. I ordered high PG I would have to go look again buy I know it's high.
Old January 14th, 2014, 08:46 PM   #210
junkyardjon
Pg and higher nic give the throat hit.
junkyardjon is offline   Reply With Quote
Old January 15th, 2014, 03:41 PM   #211
Jiveturkey3
I just got the batteries and clearomizers and am starting on the path to no smokes. Wish me luck.
Old January 15th, 2014, 05:22 PM   #212
creeping death
I'm that guy.
creeping death's Avatar
good luck! it's still working for me.
this is my set up now. i tried many different top and bottom feed tanks and so far i like this pyrex dct bottom feed tank the best. it's $15 for the tank and $3 for replacement wicks. the last 2ohm wick lasted me a month in this. the others i've tried in the other tanks only last about a week before they need replacing.
the battery is a variable voltage (3.3v-4.8v) 1300Mah
Old January 15th, 2014, 07:41 PM   #213
Jiveturkey3
How long before I can expect my lungs to go into purge mode? I remember this from the last time I quit and it's the worst part. That's scary shit.
Old January 15th, 2014, 07:42 PM   #214
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
a week or so.
Old January 15th, 2014, 11:41 PM   #215
MonkeyBiz
Master Cocksman
MonkeyBiz's Avatar
If it is a light flavor, then using a higher ohm coil with the eGo may increase flavor.
If it is a strong flavor, then using a lower ohm coil with the eGo may increase flavor.
Old January 16th, 2014, 01:53 AM   #216
BadMoonRacing500
Freedom isn't Free
Nice. I was thinking 4.2 with a 2.2 coil, but may start at 4.0-3.7
Old January 16th, 2014, 09:16 AM   #217
89Laredo
89Laredo's Avatar
3.7/2.2 is prefect for me.
Old January 16th, 2014, 10:56 AM   #218
creeping death
I'm that guy.
I'm using 4.3/2.2 without any complaints.
Old January 17th, 2014, 08:39 PM   #219
creeping death
I'm that guy.
thought I would check out a few new flavors today. I was able to sample them at the store and the waffle flavor taste like it will be excellent with my morning coffee.
Old January 17th, 2014, 08:52 PM   #220
jbsjunk
Little Member
jbsjunk's Avatar
Looks like a drug lab.
Tags
meballs, ss is a homo!
Page generated in 0.46240 seconds with 82 queries
