Shock Towers from Barnes 4wd! - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 27th, 2013, 05:28 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default Shock Towers from Barnes 4wd!
Barnes 4wd Shock Towers
Barnes 4WD Frame shock towers are great way to get your Air shocks, Coilovers or ORI struts out boarded and mounted to your frame. These shock towers are made from steel. Sure we could have made them out of 3/16 and saved some money but we did not feel that would withstand the abuse that rigs are now seeing. These Shock towers measure 14 to the top of the frame and can easily be shortened so you can mount them in just the right height for your shock length and ride height. Our design allows you to weld in the shock tabs for a double shear mount at you desired shock mounting width. For any additionally needed strength you can our large gusset to each side of the shock tower. Most customers find that our Bent Axle Shock Bracket is the best fit for this shock tower. These shock towers are sold in pairs.
Barnes 4WD Frenched shock towers are great way to get your Air shocks, Coilovers or ORI struts out boarded so they can work to their full potential. These shock towers are made from steel. Sure we could have made them out of 3/16 and saved some money but we did not feel that would withstand the abuse that rigs are now seeing. These Shock towers measure 16 long so you can mount them in just the right height for your shock length and ride height and then cut off the extra. Our design allows you to weld in the shock tabs for a double shear mount at you desired shock mounting width. For any additionally needed strength you can our large gusset to each side of the shock tower. Most customers find that our Behind The Axle Shock Bracket is the best fit for this shock tower. These shock towers are sold in pairs.
Barnes 4wd is offline   Reply With Quote
Old November 1st, 2013, 08:29 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
Here is a pic of our towers installed on the rear of a TJ:
Old November 5th, 2013, 10:38 AM   #3
Barnes 4wd
Barnes 4wd's Avatar
Here are some more pics of them:
Old January 1st, 2014, 01:46 PM   #4
Barnes 4wd
Barnes 4wd's Avatar
These shock towers are great for Jeep wranglers to outboard rear shocks, or just about any other vehicle you want to add air shocks, coil overs, or struts to!
Old April 17th, 2015, 01:57 PM   #5
Barnes 4wd
Barnes 4wd's Avatar
We offer two different types of shock towers, Frenched and Frame. Both are made from 1/4" American made steel, and sold in pairs!
Old August 6th, 2015, 11:54 PM   #6
Barnes 4wd
Barnes 4wd's Avatar
We recently redesigned both our shock towers to add a cutout at the top for the shock fitting. Here is what they both look like now:
Thread Tools
Page generated in 0.22375 seconds with 41 queries
