7/8 18tpi heim joints impossible to find??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 27th, 2013, 11:40 AM   #1
Jordank520
Jordank520's Avatar
Default 7/8 18tpi heim joints impossible to find???
Hey, i recently purchased a tie rod that some one made, its DOM thats tapped for 7/8 18 tpi TRE well when I went to put it on the passenger side TRE's tapper is smaller than the drivers side well I thought the solution to my problem would be just to use heim joints in place of the tre's but im having a very hard time finding heims that are 7/8 18tpi everything i find is 14tpi
Does anyone know where to find 7/8' 18mm heims LH and RH thread???
thank you in advanced
Jordank520 is offline   Reply With Quote
Old September 27th, 2013, 12:37 PM   #2
buttercr125
I work out
buttercr125's Avatar
What is a 7/8' 18 mm? You're using standard and metric measurements in the same size.
Old September 27th, 2013, 01:22 PM   #3
Complete Off Road
Complete Off Road's Avatar
7/8-18 is a standard GM D60 tie rod end. 18 threads per inch, not mm.
Complete Off Road is offline   Reply With Quote
Old September 27th, 2013, 01:35 PM   #4
Jordank520
Jordank520's Avatar
Oo thank you sorry my mistake on the measurements it is threads per inch
Old September 27th, 2013, 01:56 PM   #5
MiNi Beast
MiNi Beast's Avatar
No heims for that measurment. Been down that road myself. I just did away with tre all together to run just heims and ran 1.5 vs 1.25 tube for more beef.
Old September 27th, 2013, 01:58 PM   #6
Complete Off Road
I don't know of anyone making 7/8-18 heims, but a solution to your problem could be either:
Tie rod reamer
http://completeoffroad.com/i-122857-...-in-u-s-a.html
or a tie rod over bushing
http://completeoffroad.com/i-123283-...ana-44-60.html
or you could also just have the wrong tie rod end. There are four GM one-ton tie rod ends we sell, and two have a larger starting and ending diameter than the other two.
Hope this helps.
Old September 27th, 2013, 02:29 PM   #7
Jordank520
Jordank520's Avatar
What's strange is the driver side tre fits my stock 78 dana 60 knuckle and the passager side is to small.. Idk why someone would do that
Page generated in 0.31064 seconds with 44 queries
