2009 jk oil issue - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 27th, 2013, 09:42 AM   #1
Firemedic168
Firemedic168's Avatar
Default 2009 jk oil issue
have a 2009 4 door jk that is using almost 2 quarts of oil every 5000 miles, jeep not smoking, no leaks underneath, no visual leaks on engine or valve cover. any suggestions as to what is going on?
Firemedic168 is offline   Reply With Quote
Old September 27th, 2013, 09:49 AM   #2
xj4life
xj4life's Avatar
goggle "jk oil consumption". actually 2qt every 5k is pretty good. 1qt per 1k is within "spec"
i keep and eye on my Trip B odometer and just make sure i check the oil every 1k miles. within the last 5k-7.5k miles i've gone from over 1qt/1k down to maybe 0.5qt/1k. not sure why but swapping out a new pcv valve may have helped
Old September 27th, 2013, 10:08 AM   #3
scrambled82
scrambled82's Avatar
Mine does too, change your pcv valve if you haven't done it recently.
scrambled82 is offline   Reply With Quote
Old September 27th, 2013, 10:57 AM   #4
creeping death
I'm that guy.
creeping death's Avatar
this is a very common problem and Chrysler put a new short block in our 09 four door for this same reason. hopefully you are the original owner and purchased it during their lifetime drivetrain warranty offering.
here is the thread on ours, there is some good reading in there.
JK: Oil Consumption Test - Great Lakes 4x4. The largest offroad forum in the Midwest
Page generated in 0.18272 seconds with 36 queries
