New Link Brackets From Barnes 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 26th, 2013, 02:17 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default New Link Brackets From Barnes 4wd
Check out some of the new link brackets we offer at Barnes 4wd!
Looking to increase the life of your suspensions joint? Then the Barnes 4wd Horizontal four Link Truss Bracket is just what you are looking for! By orienting the joint horizontally the joint does not have to flex as much because the joint can move with the axle. We offer this bracket in three different bolt hole sizes and you can run any joint with a 2 5/8 or smaller mounting width. This bracket is cut from steel. $27.45.
Horizontal Four Link Truss Bracket
Running your joints horizontally can be a great option for upper control arms. These brackets weld to the inside of your frame and we offer them in multiple configurations. These are sold individually. $11.30.
Horizontal Frame Link Bracket
Perfect for a three link or four link suspension system. These brackets are made to be welded to the side of your frame and can be used with any suspension joint that has a 2 5/8 mounting width or smaller. These are sold in individually. $21.98
Upper Inner Frame Link Mount
Barnes 4wd is offline   Reply With Quote
Old January 29th, 2014, 09:22 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
We also have our flush mounted lower triangulated 4 link brackets online!
You can find all our link brackets on our website here.
Thread Tools
Page generated in 0.28514 seconds with 29 queries
