Dual Pull Winch Plate from Barnes 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 26th, 2013, 11:40 AM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default Dual Pull Winch Plate from Barnes 4wd
Dual Pull Winch Plate!
The Barnes 4WD Dual Pull Winch Plate was an idea born out of necessity. More and more rigs are tackling harder obstacles than ever. And with today's supper flexible suspension systems it is often helpful to "suck down" the front of your rig so that the suspension will not unload on a steep incline. This is where the Dual Pull Winch plate shines. Our winch plate has two opening one on the front for vehicle extraction and one on the bottom to so you can run your winch rope straight down to your axle. Your rope will need to just have a thimble end on it like the Master Pull rope in the picture so that you can easily thread the rope through either Fairlead. The Fairlead mount are the common 10" bolt pattern and the winch bolt mounting pattern is a 10" x 4.5" to accommodate a variety of winches. The winch pate is 26" or 33" wide and can be easily adapted to your rig.
Find them HERE
Barnes 4wd is offline   Reply With Quote
Old January 22nd, 2014, 09:00 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
Our dual pull winch brackets are great for using the same winch to suck down your front end on climbs, and for your main recovery winch. They are in stock and priced great all the time!
Old September 16th, 2014, 07:16 PM   #3
Barnes 4wd
Barnes 4wd's Avatar
The Barnes 4WD Dual Pull Winch Plate is available in 2 different sizes. 26 and 33 inches wide. The Fairlead mount are the common 10" bolt pattern and the winch bolt mounting pattern is a 10" x 4.5" to accommodate a variety of winches. These are great for those who want a to use their primary winch as a suckdown as well!
Thread Tools
Page generated in 0.20333 seconds with 32 queries
