Rear Coil Spring Relocation Kit from Barnes 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 25th, 2013, 07:48 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default Rear Coil Spring Relocation Kit from Barnes 4wd
Barnes 4wd Rear Coil Relocation Kit!
The Barnes 4WD Rear Spring relocation kit can be used on either a TJ or LJ. This kit can be used to locate the upper coil spring in a vertical position or works great when stretching your wheel base. You can still use your factory or aftermarket bump stops with this kit. Welding and cutting will be needed. Like all of our products this kit is laser cut and made in the USA. Kit includes parts for both rear springs!
Find the kit HERE
Barnes 4wd is offline   Reply With Quote
Old June 11th, 2014, 09:03 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
Combine our Rear Coil Spring Relocation Kit with one of our Link Suspension Kits and stretch the rear wheel base of your TJ or LJ Wrangler. We have all the parts you need to increase the wheel base and make your Jeep more stable on the trails at Barnes4wd.
Old August 20th, 2014, 03:38 PM   #3
Barnes 4wd
Barnes 4wd's Avatar
Here is an installed photo the Barnes 4WD Rear Coil Spring Relocation Kit. These kits are available on our website, for $76.42:
Thread Tools
Page generated in 0.24029 seconds with 32 queries
