Shot body mounting points - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2013, 08:42 PM   #1
upchuck
upchuck's Avatar
Default Shot body mounting points
My 05 Tj already has two body mounts rusted at the tub channel. What is the common fix? There isn't enough space in between the frame and tub to work.
Do people just weld new 3/16" the length of the channel with predrilled and tapped holes?
upchuck is offline   Reply With Quote
Old October 25th, 2013, 04:36 PM   #2
upchuck
upchuck's Avatar
bumpity
Old October 25th, 2013, 08:54 PM   #3
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Someone makes a new channel that you weld in with the nuts already installed.
Old October 28th, 2013, 06:58 PM   #4
upchuck
upchuck's Avatar
thank you
Old October 28th, 2013, 08:24 PM   #5
yyj87
yyj87's Avatar
On my yj I cut strips and welded them on creating a c Chanel to case the old rail. I then used 1.5" hole saw to expose the top of the inside of the rail. I welded a nut to a large washer, inserted from the top, tightenedthe bolt and wwelded the nut washer combo to the inside of the rail. I then tacked the pace the hole saw removed over the hole.
It was a lot of work but it is solid!
yyj87 is offline   Reply With Quote
Old October 29th, 2013, 07:04 PM   #6
upchuck
upchuck's Avatar
that's my thought, blow off the stub sticking up behind the seat inside and refab something all the way thru from there down. Here comes another round of salt
Old October 30th, 2013, 08:54 PM   #7
Gogolen
They're called torque boxes. Classic Enterprises makes replacements in both full length and the back half.
http://www.classicent.com/jeep.php#TJ
Gogolen is online now   Reply With Quote
Page generated in 0.14619 seconds with 44 queries
