LP D30 Slop in the pinion yoke? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2013, 07:11 PM   #1
skife
skife's Avatar
Default LP D30 Slop in the pinion yoke?
I've got some up and down slop in the yoke, haven't measured it but probably +-.040"
is this normal? or should i be looking into swapping to a HP30 already?
Old September 24th, 2013, 07:19 PM   #2
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
not normal
Old September 24th, 2013, 07:25 PM   #3
How long has it been like that? Have you tried tightening the nut?
Old September 24th, 2013, 07:28 PM   #4
skife
skife's Avatar
no idea how long its been like this, after i lifted it the drive shaft is at more of an angle and is now moving it up and down when it moves, it didn't before i lifted it because it was at less of an angle, who knows how long its been sloppy. it was getting dark and i didn't have time to tighten it, i'll do it tomorrow.
Old September 24th, 2013, 07:30 PM   #5
jbsjunk
Little Member
jbsjunk's Avatar
Originally Posted by hosejockey4506 View Post
not normal
x2. Shouldn't be any side to side movement. Can kill gears that way. Do check the pinion nut. A tight driveshaft joint helping it
Old September 24th, 2013, 09:01 PM   #6
yyj87
yyj87's Avatar
Its broke..... buy a kit and make it not broke.
yyj87 is offline   Reply With Quote
Old September 25th, 2013, 01:03 PM   #7
skife
skife's Avatar
A kit?
If it needs work I've got a line on a hp30 compete rotor to rotor for $75
would rather swap a hp then fix a lp
Old September 25th, 2013, 01:44 PM   #8
Most likely if it's been like that for quite a while the gears and pinion bearings have some damage.
Old September 25th, 2013, 08:25 PM   #9
skife
skife's Avatar
Question
Its a great excuse to upgrade to a high pinion
Old September 26th, 2013, 05:48 AM   #10
yyj87
yyj87's Avatar
Originally Posted by skife View Post
A kit?
Perfect!
Old September 26th, 2013, 06:46 AM   #11
redhead_823
redhead_823's Avatar
I ran a D35 sloppy like that for a while. I replaced the pinion bearings, but the gears were worn so bad it still whined constantly. I figured a ZJ running on 5 cylinders and no 4x4 wasn't worth a set of gears. Traded it in on my Caddy.
Anyways... buy the HP and scrap the other one.
redhead_823 is offline   Reply With Quote
Old September 26th, 2013, 06:53 AM   #12
yyj87
yyj87's Avatar
Fozy lock it and hook the vaccum disco so that its manually controlled... polocks selectable!
Old September 26th, 2013, 10:07 AM   #13
skife
skife's Avatar
Vac disco ended in 91 on xjs
Old September 26th, 2013, 05:10 PM   #14
yyj87
yyj87's Avatar
No Pollock selectable for you!
Page generated in 0.32282 seconds with 65 queries
