7.3 super duty oil pan - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2013, 01:09 PM   #1
14muddn
Default 7.3 super duty oil pan
I've noticed a drop of oil under my truck after it's parked overnight. I haven't crawled underneath to check it out yet but I know it had some surface rust starting last time I was under so I'll prepare for the worst.
Should it be time for a new oil pan is there a way to replace it without pulling the motor? I'm not really interested in chopping up the crossmember since a. I only have a 135 amp mig welder and b. I don't want to cut up structural parts on a truck I plow snow with.
Old September 24th, 2013, 01:14 PM   #2
kickstand
circling the drain
kickstand's Avatar
Are you sure its the oil pan and not the lines?
I smeared Grease all over my oil pan every time I changed the oil to keep it from rusting, we used to do that with a lot of our heavy equipment years ago when I helped to maintain a fleet of trucks at a construction company to prevent the pans from rusting. We'd paint them and then smear wheel bearing grease all over them.
Old September 24th, 2013, 01:14 PM   #3
frdboy
frdboy's Avatar
Unfortunately, the only right way is to pull the motor, I normally replace up-pipe gaskets and oil cooler O-rings at the same time. You will need to remove the turbo so get O-rings for that and the pedestal. The pan gasket should be ultra grey RTV and I normally sand and re-paint the new pan as what comes on them is very thin.
Old September 24th, 2013, 01:29 PM   #4
14muddn
I'm not sure yet it's something I have been curious about though since I know it's a weak link on these trucks among other things. It is due for an oil change pretty soon so I'll check it out at that point.
If it isn't the oil pan I will get some por 15 and start using your method
Old September 24th, 2013, 01:36 PM   #5
kickstand
circling the drain
kickstand's Avatar
Yeah, I thought my oil pan was rusted through but it appeared to be actually leaking from somewhere above the pan on the back of the motor on the passenger side.
Old October 19th, 2013, 03:21 PM   #6
hondadirtracer
Skymaster
hondadirtracer's Avatar
It could also be your dipstick where it comes out of the oil pan. They sell repair kits for those which are about $300. You can do it without removing the oil pan too.
http://www.strictlydiesel.com/p-2690...epair-kit.aspx
hondadirtracer is offline   Reply With Quote
Old October 19th, 2013, 03:30 PM   #7
Cool parts peddler
Ironman Offroad's Avatar
Pull the cab.
Lift the motor up about a foot and the pan comes right out.
Done a couple that way.
Old October 20th, 2013, 08:12 AM   #8
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
Pull the cab.
Sounds harder than pulling the motor
Old October 20th, 2013, 08:30 AM   #9
kickstand
circling the drain
kickstand's Avatar
Except pulling the motor on those trucks is a lot easier with the cab removed.
Old October 20th, 2013, 09:13 AM   #10
junk90xj
ALLPRO AUTO
junk90xj's Avatar
I pull the trans, lift the motor up and the pan slides right out. Easiest way to do it IMO.
Pulling the motor or pulling the cab takes a lot longer
http://www.apalansing.com/
Old October 20th, 2013, 09:56 AM   #11
tom77cj5
tom77cj5's Avatar
The motor comes out in about 3hrs labor. Its actually pretty easy. You don't have to pull the cab. Take the front end off. Disconect the trans and support it. Pull motor out. Only pulled mine cause I blew the trans but while it was out I did a pan and head studs. Nice part is you can make it pretty while its out. I drove my truck for ten years and sold it for what I payed for it lol
Old October 21st, 2013, 01:05 PM   #12
kickstand
circling the drain
kickstand's Avatar
Originally Posted by tom77cj5 View Post
[ I drove my truck for ten years and sold it for what I payed for it lol
That never sucks.
Page generated in 0.35744 seconds with 59 queries
