YJ Rocker Guards from Barnes 4wd - Great Lakes 4x4. The largest offroad forum in the Midwest
Thread Tools
Old September 24th, 2013, 12:17 PM   #1
Barnes 4wd
Barnes 4wd's Avatar
Default YJ Rocker Guards from Barnes 4wd
Barnes 4wd YJ Rocker Guards
The Barnes 4WD Yj Rocker guard provides both the best in tub protection and functionality. Our rocker guards are made from 3/16 steel that is laser cut and CNC bent so that they will fit every time. They extend from wheel well to wheel well to make sure that your entire tub is protected and tie into two of the tub mounts so they can be abused every time you wheel with our worry. The Barnes 4WD rocker guards not only protect 6 vertically of your tub but also maximize under the tub protection as well with extended steel section under the tub. Our Rocker Guards also come with counter sink mounting holes and Stainless Steel Mounting hardware and lock nuts. These will Work with all body lifts.
Barnes 4wd is offline   Reply With Quote
Old August 11th, 2014, 12:14 PM   #2
Barnes 4wd
Barnes 4wd's Avatar
A couple pics of our YJ rocker guards from one of our customers. They are made in the USA from USA steel and in stock!
Find them here: Barnes 4WD YJ Rocker Guards
Thread Tools
Page generated in 0.16367 seconds with 29 queries
