JD Gator Suspension - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 25th, 2013, 08:46 AM   #21
Flexin' XJ
Flexin' XJ's Avatar
I think I found some Gabriel hijackers that might work. Got a set coming. Being there is no spring and just the air I don't know how they will work but they are pretty cheap if it doesn't work out.
Sent from my HTC6435LVW using Tapatalk 4
Flexin' XJ is offline   Reply With Quote
Old September 25th, 2013, 10:34 AM   #22
Flexin' XJ
Flexin' XJ's Avatar
You guys are correct. These coilovers CAN be taken apart. I removed one to install the air shocks and I see the top retainer has a cutout to take it apart. I will see if these air shocks work and go from there but at least I know they do come apart. Kudos.
Old September 25th, 2013, 10:34 AM   #23
Mr.Green
I can levitate!
Mr.Green's Avatar
Originally Posted by nickb304 View Post
compress spring. make split collars to take up some more room to pre load the spring. use some hose clamps to keep them from popping out. or does it possibly have different upper shock mount locations like a Polaris ranger? changing the leverage ratio on the shock by moving the top mount out farther making the shock more vertical.
Adding preload will not solve his problem, but making the shocks more vertical would help. Not 400 lbs help, but it would help.
Old September 25th, 2013, 11:21 AM   #24
Flexin' XJ
Flexin' XJ's Avatar
First pic is factory unit, second is Gabriel air shock
ID:	110735   Click image for larger version
Old September 25th, 2013, 11:38 AM   #25
Lousypirate
Whoop Whoop
Lousypirate's Avatar
There is s slot right there too disassemble....
Probably should have caught myself up on this thread before posting lol
The Kernel (46 CJ2a)
Wow, i would lick those...
Old September 25th, 2013, 12:17 PM   #26
Flexin' XJ
Flexin' XJ's Avatar
Well, these air units won't work. I didn't know they were also a shock. One end is air, the other normal shock. They are ment to be used along with the factory leaf spring. So when I air them up it just moves the assembly upward until the shock portion bottoms out. At least I know what vehicle parts I can use on these units. 95-06 Ford Windstar.
Old September 25th, 2013, 02:20 PM   #27
joe_jeep
welfare wheeler
joe_jeep's Avatar
thought about using a "timbren"?
they work very well and are cheap.
very popular in the overloaded truck camper crowd.
Old September 25th, 2013, 02:23 PM   #28
Flexin' XJ
Flexin' XJ's Avatar
If you look at the second picture I posted above I think there is too much room for a timbren. I could custom fab a drop mount.
Old September 25th, 2013, 03:42 PM   #29
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
What's the ID on the spring? 2.5 or 3.0 would make it pretty easy to bump up the spring rate, but that could bring the suck when riding empty.
Old September 25th, 2013, 08:06 PM   #30
Flexin' XJ
Flexin' XJ's Avatar
The empty ride quality would be the downside to stiffer springs but I could buy another set and keep one with the stiffer spring and just swap them twice a year.
Old September 25th, 2013, 08:23 PM   #31
skife
skife's Avatar
Dual rate Springs
Old September 25th, 2013, 09:04 PM   #32
Flexin' XJ
Flexin' XJ's Avatar
Originally Posted by skife View Post
Dual rate Springs
Do you think the State is made of money?
Old September 26th, 2013, 09:27 PM   #33
Ebs
Measure the coil diameter, ebay a comparable junkyard set from something heavier, cut to length.
It might ride like an unloaded dump truck, but it won't bottom out.
Old September 29th, 2013, 07:52 PM   #34
joe_jeep
welfare wheeler
joe_jeep's Avatar
timbren with a drop mount. its cheap, easy, and wont affect empty ride quality,
they can be bought in many different weight capacity ratings.
do it!
Old September 30th, 2013, 07:57 AM   #35
Mr.Green
I can levitate!
Mr.Green's Avatar
Something like this would work too. It increases spring rate and increase the "loaded" ride height by not letting the spring totally collapse when loaded up. You can use more than one. It fits in between the coils, it is not a "budget boost" puck.
http://www.ebay.com/itm/like/370820335583?lpid=82
Old October 10th, 2013, 11:06 AM   #36
Flexin' XJ
Flexin' XJ's Avatar
I have a couple Monroe Load adjusting shocks on their way to try. They say they give 1200lbs extra capacity so we will see.
Also, we are going to buy 3 new Bobcat 3600 UTVs. Higher weight capacity, better cabs, heat and A/C, manufactured with Polaris Brutus units. Hydrostatic transmission which will be better for plowing due to no more shifting forward or reverse.
Page generated in 0.36032 seconds with 72 queries
