Fuso - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2013, 09:45 AM   #1
cerial
Direct Drive FTW
cerial's Avatar
Default Fuso
Parked next to this guy and could not help but check out the drive train.
Very tight, compact, drop down case, heavy duty axles. Front of the motor to the back of the transfer case was around 5 feet. Both axles are center drop. Axles look to be 1+ tons with large hubs/knuckles. The tires were 16".
Someone could take a jeep FC cab, drop it on this chassis, bolt on some 38"s and have a very cool rig.
Old September 24th, 2013, 09:51 AM   #2
kickstand
circling the drain
kickstand's Avatar
That, would be an awesome set up for your buggy.
Old September 24th, 2013, 10:33 AM   #3
ajmorell
don't, just don't
Old September 24th, 2013, 10:38 AM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
Lol
H.o.r.e
Old September 24th, 2013, 10:41 AM   #5
SS
Bananarama!
SS's Avatar
This thread sucks.
-Jer
Old September 24th, 2013, 10:42 AM   #6
buttercr125
I work out
buttercr125's Avatar
LOL at post #2 and 3.
Old September 24th, 2013, 11:18 AM   #7
cerial
Direct Drive FTW
cerial's Avatar
I looked it up a bit. The front axle is rated for close to 5000 lbs with a 5.8 ratio. The wheelbase is 135<+/-. 140-160 HP diesel engine mated to an overdrive automatic. The axles are trussed and not much larger then a 1 ton.
I just thought it was a cool little FC.
Old September 24th, 2013, 11:30 AM   #8
Skooter_Built
Fuck talk, Duck walk!
Skooter_Built's Avatar
I think this is not a good idea.
I'm the man in White.
Old September 24th, 2013, 11:39 AM   #9
brewmenn
Mr. Special Snowflake.
brewmenn's Avatar
T-case looks like it hangs quite low.
Old September 25th, 2013, 01:01 PM   #10
cerial
Direct Drive FTW
cerial's Avatar
With 235/85/r16 tires(31.7" tall) the clearances from the ground are 9" front diff, transfer case 11", rear axle 8". The front diff is slightly offset toward the passenger side and is 12" tall. The rear axle is 14" tall. This model is running 4.875 gears. The knuckles are massive both diffs are shaped round and trussed in the shape of an elongated diamond.
The thing is heavy as heck in stock form. But as a expedition rig or a base for a restromod FC it would be cool. The front axle is what caught my eye. They are not much bigger then a 1 ton. The front has locking hubs and the rear is full floating.
I think axles rated 2 times what 1 ton's are while similar in size would interest a 4wd community. The drop down case could be clocked with a bit of skill thrown in or ran in something Mud related. It is a heavy truck designed to have a box full of heavy stuff so the transmission would seem like a good candidate for abuse. The motors range in power. Being a cab over you know the motor is packaged tightly even with the turbo option. This being a commercial application you also know the motor is run conservatively for longer life. Someone could mate a different engine with more power in front of the automatic. Getting it to shift right would be fun though.
Like I said before I just thought it was a cool FC.
Old September 25th, 2013, 02:11 PM   #11
scare-crow
the eskimo bro
scare-crow's Avatar
Send a message via AIM to scare-crow
I bet you could build an awesome buggy out of that thing. Even better yet, build a sick plastic body and put 54s on it.
scare-crow is offline   Reply With Quote
Old September 25th, 2013, 04:26 PM   #12
dreezy
Haggard Fab
dreezy's Avatar
Here is your donor rig
http://www.commercialtrucktrader.com...o-FE-110996118
Old September 25th, 2013, 06:40 PM   #13
Trail Junkie
iamfawkinwithyou
Trail Junkie's Avatar
Originally Posted by dreezy View Post
2x4
Page generated in 0.25286 seconds with 61 queries
