Snow Stops for metal roof, what works for you? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 24th, 2013, 09:15 AM   #1
Default Snow Stops for metal roof, what works for you?
I need to put snow stops on the roof of the barn this year before the barn. Last year, we'd have large snow slides that make a huge mess and are a safety hazard.
Anyone have experience with putting them up? Did you do one stop in each 'groove' of the roof?
I believe my roofing as called R-panel. Ribs are 9" on center, and the roof is through-fastened (not standing seam). So I am planning to use screws to attach the stops to the roof. I have not heard anything good about peel and stick adhesives, and I don't think we have enough doors above 50* for the good adhesive to work.
Roof is 4/12 pitch, probably about 18-19 feet from peak to edge.
Old September 24th, 2013, 01:29 PM   #2
Wehan
Wehan's Avatar
http://snoblox-snojax.com/ my work uses something like the clear plastic ones.
Wehan is offline   Reply With Quote
Old September 24th, 2013, 02:20 PM   #3
Mr.Green
I can levitate!
Mr.Green's Avatar
North Carolina
Old September 24th, 2013, 03:11 PM   #4
North Carolina
Banana
Old September 24th, 2013, 04:28 PM   #5
buildingup
Interested in this for my house but I have standing seam
Sent from my DROIDX using Tapatalk 2
buildingup is offline   Reply With Quote
Old September 25th, 2013, 06:00 AM   #6
Tizken
Dynamic Fastener has quite a few options, they are a supplier for metal building hardware.
http://www.dynamicfastener.com/
Tizken is offline   Reply With Quote
Old September 25th, 2013, 06:41 AM   #7
cerial
Direct Drive FTW
cerial's Avatar
On a 4/3 rib sheet laid out with the left side of the sheet covering the right side of the previous sheet(guessing you have 4) you want to place them in the 2nd rib from the rib covering the previous sheet.
Blue=High rib with highest screw in it
Red=Snow stopper
White=Nothing
Green=Covered rib
This prevents snow and ice pushing the next sheet covering the 4th rib up between the screws and causing water to leak onto the insulation.
Be smart about it and use some scaffolding or something along those lines under where your working in case you slip.
Old September 25th, 2013, 06:50 AM   #8
cerial
Direct Drive FTW
cerial's Avatar
One more thing don't use those crappy plastic ones. They will look like hell after a few years. If you roof is exposed add some style to it by cutting out some steel and making your own small lightweight stoppers.
Some 3/16 metal cut out, bent, then power-coated to match the roof makes it look like they belong there.
Or you can go contrasting colors with a small design or phrase like this.
* * * * M E B A L L S * * * *
Old September 25th, 2013, 08:43 AM   #9
FlatFender
Tap Tap Splat
FlatFender's Avatar
North Carolina
No. We're full.
Old October 17th, 2013, 12:52 PM   #10
OK, got these installed this week. Well, I did the front, I still have to go do the back roof.
I figured I would take Cerial's advice, and do the opposite, since that usually works out best. These are from SnoBlox, this is the 'Deuce' model. They are clear, and really disappear into the roof from further back. I don't really care about that one way or the other, but some might. You can see how much they disppear into the first two pics (same pic, just zoomed in a little bit) One every 9", in a staggered row. Installed pretty easy, they are dimpled for drilling, so I predrilled each one, then use a hammer to set the self-drilling screws (monster #14 screws with hex heads) into the steel. The complete bottom is covered in a thick layer of sealant, and it comes up around the screw heads also, which also have a sealing washer. Once I got the rythym down installing them, it went pretty easy. Setting the screws with a hammer helps a lot, and I used an impact driver, compared to a drill. Here's a couple pix.
ID:	111451   Click image for larger version
ID:	111452   Click image for larger version
ID:	111453   Click image for larger version
Old October 17th, 2013, 12:56 PM   #11
14muddn
I really like your barn
Old October 17th, 2013, 01:02 PM   #12
firehawk
Live Action!
firehawk's Avatar
x2 can I store some stuff there?
Old October 17th, 2013, 02:03 PM   #13
Sure, you can store any of those wrecked G8 engines you want. But its a bad neighborhood, and I'm pretty sure its gonna get stolen...
Old December 23rd, 2013, 02:42 PM   #14
Update: so, we had about five inches of snow up on the roof. After 4 days above freezing including a lot of rain, the stops are working perfectly. Very happy with it all, not a drop has slid off the edge. Normally that whole roof would have slid down the first day it was above freezing. You can see how much has melted, that is clear roof now at the peak. But none of that has slid past the stops. So, happy customer here....
Tags
meballs
Page generated in 0.49067 seconds with 65 queries
