solid motor mounts?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 23rd, 2013, 12:42 PM   #1
davidkassie
davidkassie's Avatar
Default solid motor mounts??
have a 87 k5 and am wondering if I should run solid motor mounts or not.. aftermarket energy suspension mounts are flexing pretty bad.. no cage or anything.. good idea or no?
davidkassie is offline   Reply With Quote
Old September 23rd, 2013, 12:53 PM   #2
AFRd_CJ5
AFRd_CJ5's Avatar
What's the drivetrain setup? How do you know they are moving that bad?
AFRd_CJ5 is offline   Reply With Quote
Old September 23rd, 2013, 01:00 PM   #3
in2deep
Hole tester
bad idea way to much frame flex I would for see cracked block or frame
id would make them out of dom and urethane bushing
Old September 23rd, 2013, 04:01 PM   #4
AFRd_CJ5
AFRd_CJ5's Avatar
Possibly, but not a sure thing. We've ran them for years on stock frames and stock blocks.
Old September 23rd, 2013, 07:12 PM   #5
davidkassie
K.. 4.56 gears.. half ton axles.. th400. Np208.. 406.. worried about twist as well
Old September 23rd, 2013, 07:49 PM   #6
AFRd_CJ5
AFRd_CJ5's Avatar
What are you seeing that you know the mounts are moving bad? You're not going to get rid of frame flex unless you tie in a good cage.
Old September 23rd, 2013, 10:24 PM   #7
davidkassie
It seems to move around a lot while its camming at idle.. shakes a lot.. not like a balance issue.. just while hitting at idle. I have had street cars with solid mounts and seemed way better...
Old September 23rd, 2013, 10:44 PM   #8
Nuggets
I fix stuff!
Nuggets's Avatar
Replace tired old oil soaked mounts with some fresh ones.
Old September 23rd, 2013, 11:10 PM   #9
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Pretty much. And mounts are supposed to do just what they are doing....let the engine move and not transfer that movement to the chassis. A cammed motor with solid mounts is going to shake the shit out of you.
Old September 24th, 2013, 11:38 AM   #10
AFRd_CJ5
AFRd_CJ5's Avatar
I've had some pretty "healthy" motors on poly and stock mounts and never seemed to notice that much movement, but it's not like I was looking for it either. If you've used solids in the past, then you know what to expect. At that point, it's just a personal choice.
Old September 24th, 2013, 12:17 PM   #11
davidkassie
I appreciate it, just a thought is all. I will probably just put a limiting strap on the drivers side, just in case.. ty!!
Old September 24th, 2013, 12:51 PM   #12
Coyote Red
Coyote Red's Avatar
You may want to consider limiting both sides of the engine. I was tearing both sides of mine before I chained them down.
I believe AutoFab has some poly/DOM mounts that will fit your K5.
Coyote Red is offline   Reply With Quote
Old September 24th, 2013, 12:57 PM   #13
AFRd_CJ5
AFRd_CJ5's Avatar
I've used a limiting strap on both turbo Buick's I had in the past. And I've seen chains on other vehicles, but I've never done that.......
Old September 24th, 2013, 12:58 PM   #14
AFRd_CJ5
AFRd_CJ5's Avatar
How would a limiter help on the passenger side?
Old September 25th, 2013, 10:03 AM   #15
frdboy
frdboy's Avatar
For the OP stock style mounts would probably be best but I had solid mounts in my mustang and you could not even tell and I had a lil cam in it.
Page generated in 0.30311 seconds with 68 queries
