2008 Cummins 6.7 Power Loss /CEL's - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 22nd, 2013, 06:22 PM   #1
9T9BlueTJ
Motivator, please!
9T9BlueTJ's Avatar
Default 2008 Cummins 6.7 Power Loss /CEL's
Out of the blue today, I get 2 CEL's while towing, and the truck went into limp mode. I could accelerate to almost 60, but took time getting there. I was towing around 5000 lbs and with the limp mode and 2 CEL's, I also got the OH message to get serviced immediately, and contact dealer (did not say what to get serviced immediately), and a lot of black smoke while towing. I got a P1011 (low system fuel pressure) and a P0087 (Fuel rail system pressure too low).
To narrow down what could be the cause, I did some internet research, and got some things to try (or have some one look at). Are all these potential causes of this sudden loss of power? Truck has 70,000 miles.
Try a shim kit or fuel rail plug
Fuel filter (this will be changed soon - 13,000 since last changed)
Update software on the XRT Pro tuner (downloading that now - been almost 2 years since I updated it)
Faulty pressure relief valve on fuel rail (does the shim /plug above do the same thing?)
FCA faulty
Weak fuel pump
Weak fuel transfer pump
Fuel rail sensor
Dirty MAP sensor (I cleaned this around 10,000 ago)
Injectors leaking into crankcase? Something about to check the oil level and if high, this is it. Also a white paper towel test to see if there are 2 colored rings on it?
CP3 needs replacement
Faulty crank position sensor. Truck starts and idles nice though
May be a lot of algae in the tank / system (I use treatment every time I fill up, and keep the tank full 90% of the time)
Any other suggestions, or something that I can remove from the list above?
Any suggestions for a shop in SW Mich that is within limping distance that would look at this (I'd really rather not take this to a Chrysler dealership).
9T9BlueTJ is offline   Reply With Quote
Old September 22nd, 2013, 06:59 PM   #2
masterbeatty
masterbeatty's Avatar
Stay far away from dieseltech believe there gr kzoo area.
Old October 3rd, 2013, 07:34 PM   #3
feelmeccummin
feelmeccummin's Avatar
Figure out your rail pressure and fuel pressure first . Is your DPF and EGR deleted?
feelmeccummin is offline   Reply With Quote
Old October 3rd, 2013, 07:43 PM   #4
TanTahoe
TanTahoe's Avatar
What kind of power do you have on your programmer? Might be bleeding the fuel system if you are on a higher HP level when you get on it. A lift pump would help if this is the case. Not sure if they could help you out or point you in the right dirction, but Merchant Auto is on the west side. They specialize in Duramax but might know who to get in touch of for Cummins on the west side.
TanTahoe is offline   Reply With Quote
Old October 3rd, 2013, 10:39 PM   #5
Toivo
Feel lucky?
Toivo's Avatar
Pm sent
Old March 3rd, 2014, 06:38 PM   #6
mprmn08
mprmn08's Avatar
engineered diesel in Allendale. not sure where u are in regards to them though. but yeah like said deff not dieseltech
Old March 3rd, 2014, 07:05 PM   #7
bighroder
bighroder's Avatar
The most easy and suspecting thing with these cold temps is the fuel filter. What tune are you running and do you have a lift pump? Smell the oil if there's a fuel smell replace the injectors usually on these trucks it'll run like shit have a miss or "hang" when they go bad I would suspect its a filter or lift pump issue. If you are demanding to much fuel (tune) with no lift pump on a bad filter it don't take long to kaput the ol cp3
bighroder is offline   Reply With Quote
Page generated in 0.28801 seconds with 44 queries
