What torque convertor for a 47 re behind a cummins? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 22nd, 2013, 05:24 PM   #1
Tie Dyed
O.G.
Tie Dyed's Avatar
Send a message via AIM to Tie Dyed
Default What torque convertor for a 47 re behind a cummins?
Starting to get a list for my truck swap. I have a 96 V10 4x4 and a 98 2wd cummins. The 4x4 trans will bolt right up to the cummins, but will require a different torque converter due to the stall speed differences. Both trucks have the 47re trans (at least I hope the 96 is, but from what I have read it should be). Truck tows often, usually lighter loads (~5000#), but still need a tc that can handle heavier just in case. Trans was rebuilt about 5000 miles ago.
Thanks all
2000 XJ with a 3 inch body lift
Tie Dyed is offline   Reply With Quote
Old September 22nd, 2013, 06:04 PM   #2
Lousypirate
Whoop Whoop
Lousypirate's Avatar
I think you need different governor springs too? Maybe that is just the rh.
"Stock" to mild build, it's said a good single disc.
Higher side of mild to wild a triple disc.
I'd call goerend. And browse cumminsforum.com
The Kernel (46 CJ2a)
Wow, i would lick those...
Lousypirate is online now   Reply With Quote
Old September 24th, 2013, 10:01 PM   #3
walther
I would buy a billet cover triple disc tat way you only buy a tc once
walther is offline   Reply With Quote
Old October 3rd, 2013, 07:31 PM   #4
feelmeccummin
feelmeccummin's Avatar
Save your pennies and do it once get a valve from HTS or Garmon or a place that does diesel transmissions and get a triple disk suncoast, ATS or georand. I've been running an ATS for 8 years at over 600 hp and transmission has never been out
feelmeccummin is offline   Reply With Quote
Old January 11th, 2014, 01:52 PM   #5
dirtpoor4x4
anti-jeep
dirtpoor4x4's Avatar
There is a piece in towards the tail of the trans that controls the shift point at different rpm' s the v10 runs higher rpm shift points than the 12v. They are interchangeable. I think one has a brass weight and the other is steel.
dirtpoor4x4 is offline   Reply With Quote
Old March 3rd, 2014, 06:29 PM   #6
mprmn08
mprmn08's Avatar
call engineered diesel they can set u up. I would just do a single disk billet if its under 450hp and u don't want to buy a billet input also. triple disk needs a billet input fyi
Page generated in 0.21170 seconds with 41 queries
