1985 chevy k20 on 44s (PICS UP) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 21st, 2013, 09:34 AM   #1
Sweeney
my other truck = zamboni
Sweeney's Avatar
Default 1985 chevy k20 on 44s (PICS UP)
Well, do to loss of job its time to sell one of the toys.
1985 chevy k20 8ft bed
355 jasper 650 double pumper built off road carb
Np205 (is pulled out of the truck right now due to busted input shaft)
Muncie trans
Dodge dana 60 up front
Chevy 14 bolt rear
4.10 gears
44x18.5x16.5 gumbo monster mudders
All new grounds
New front rotor hub assembly
New front brakes and calipers
Braded brake lines frome the frame to the calipers
New plugs
All U joints new or in good shape
New Mile marker lock out hubs
She still needs some work:
The exhaust needs to be done
Its gunna need a sway bar put back up front if u wanna drive it on the road
The gas tank leaks. I have another tank but I didn't put it in because I wanted to put a cell in it.
Front passenger leaf spring pack has a busted spring in it
(It really just needs a good set of arched springs to help with the little bit of rubing there is when you turn the wheel all the way.)
As always I'm sure I'm forgetting some good and bad and as I remember I will add it.
Extra parts that I have for it that can be worked in to the right deal:
Good 4 core radiator (was just gunna be a upgrade)
A bad ass rear bumper
Back window with slider (has a solid window now nothing wrong with it)
A set of 36s that I use as rollers
2 flows
Trick flow aluminum heads
I'm asking $6,500 without the extras
Open to trades for a good DD. Looking for newer chevy full size trucks.
Pics will be up Monday or u can text me at 734 788 0149
ID:	110657   Click image for larger version
ID:	110658   Click image for larger version
ID:	110659   Click image for larger version
ID:	110660   Click image for larger version
Name:	Rotor hub b4on.jpg
ID:	110662   Click image for larger version
ID:	110663   Click image for larger version
Sweeney is offline   Reply With Quote
Old September 23rd, 2013, 07:58 AM   #2
Sweeney
Sweeney's Avatar
Bump For Pics
Old September 24th, 2013, 02:42 PM   #3
Sweeney
Sweeney's Avatar
Bump
Old September 26th, 2013, 07:08 AM   #4
Sweeney
Sweeney's Avatar
Morning bumb
Old September 28th, 2013, 10:01 AM   #5
Sweeney
Sweeney's Avatar
To the top
Page generated in 0.24623 seconds with 39 queries
