YJ: need lower rear shock mounts fabricated - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 20th, 2013, 02:58 PM   #1
mymizzery
mymizzery's Avatar
Default need lower rear shock mounts fabricated
does this seem like a better design than what came stock on the YJ. both broke off, and one of them had been welded once before and broke again. this to me seem like a better design because all the force is centered above the axle instead of on the welded area behind it. this is just a first draft drawing. I would probably make it go further around the axle. and if anyone needs any CAD work done I am available. LOL.
mymizzery is offline   Reply With Quote
Old September 20th, 2013, 07:50 PM   #2
sandfox4
napadave
sandfox4's Avatar
that would be stronger, but might require a shorter shock which would limit your suspension travel, thats why they stick them lower so you have more travel
sandfox4 is offline   Reply With Quote
Old September 23rd, 2013, 11:23 AM   #3
mymizzery
mymizzery's Avatar
I am going to replace the shocks anyway. just need to figure out what size I need. I have a shackle lift on there so the travel is longer than stock so I don't see a problem getting the correct size shock in there.
Old September 23rd, 2013, 01:21 PM   #4
crazykev
crazykev's Avatar
Probably not bump stopped correctly. The shock should not be the downstop.
crazykev is offline   Reply With Quote
Old September 23rd, 2013, 01:28 PM   #5
crazykev
crazykev's Avatar
Old September 23rd, 2013, 01:47 PM   #6
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
If you weld it correctly the weld will never break when it's on the back of the axle. Plus you get a longer shock which will give you more travel.
Old September 23rd, 2013, 01:48 PM   #7
bigbchevy
missmrgreenagain
bigbchevy's Avatar
H.o.r.e
Page generated in 0.27999 seconds with 44 queries
