help with my 4.0 in xj Started all over - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 22nd, 2013, 03:06 PM   #21
WACKO1
2000 xj
WACKO1's Avatar
First off cycle the ignition key 3 times on off on off on check engine light will start to flash count the flashes,their will be a pause and then more flashes.that will give you the code
WACKO1 is online now   Reply With Quote
Old September 22nd, 2013, 03:07 PM   #22
WACKO1
2000 xj
WACKO1's Avatar
The way you did it only checks the cluster self check
Old September 22nd, 2013, 03:47 PM   #23
hghgrad
hghgrad's Avatar
The key on off trick will show the code number along with the cel flash on the 97's.
hghgrad is offline   Reply With Quote
Old September 22nd, 2013, 05:05 PM   #24
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
Send a message via Yahoo to ttrailtj
I did it, it flashed a 12, then 54 flashed 4times during the 12 a 7 times during the 54
ttrailtj is offline   Reply With Quote
Old September 22nd, 2013, 06:28 PM   #25
WACKO1
2000 xj
WACKO1's Avatar
Just checked their is no 12 code, try again
Old September 23rd, 2013, 07:48 AM   #26
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
Ok, I redid it, shows codes 12, 54, 17, 45 ,22, 45, 55, anybody ?
Old September 23rd, 2013, 10:33 AM   #27
yyj87
yyj87's Avatar
Google gave me the answers!
yyj87 is offline   Reply With Quote
Old September 23rd, 2013, 01:27 PM   #28
19914x4blazer
ps4 tag chevytruckguy82
19914x4blazer's Avatar
http://jeep-xj.info/HowtoECUcodes.htm
19914x4blazer is offline   Reply With Quote
Old September 23rd, 2013, 02:12 PM   #29
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
A new pickup coil installed and she fired right up! The code 54 was the culprit, thanks for everyones help
Old September 24th, 2013, 02:34 PM   #30
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
Well, went to drive it today, right back to a no fire ??????
Old September 25th, 2013, 11:00 AM   #31
ttrailtj
looking 4 #8 Jeep
ttrailtj's Avatar
Still showing code 54 got another pickup coil still no fire, maybe the main coil its self?
Old October 4th, 2013, 08:09 AM   #32
Dylan
Dylan's Avatar
the pickup coil (cam sensor) and main coil (assuming you ignition coil) does totally different things. You need to go back and follow the trouble shooting steps described before. You would test the cam sensor and the ignition coil in different ways.
My guess is you have a broken wire somewhere in the harness for the cam sensor. Check the pigtail for your +5v, ground, and check the signal wire for shorts back to the ECU. if that test fine, then you need to back probe the cam sensor with 5v test light or a analog meter to check for a +5v pulse while cranking an the signal wire. If you have checked the signal wires for shorts and it test ok, you can check for the pulse at either the sensor or the ecu. If you get your +5v pulse, you should NOT be getting a code 54. If you do, its internal to the ECU.
To test the coil, you will need to check resistance in the coil plug. You can also check the pigtail that plugs into the coil. You should have a +12V with key on. The ground is shorted to by the ECU to fire the coil at the correct time. If you check your coil while cranking and get a ground pulse on one of the wires, than your ECU is getting a cam signal and something is wrong with your coil (if it didn't fire).
Good luck.
Page generated in 0.32205 seconds with 59 queries
